3rd February 09, 05:22 PM
 Originally Posted by Dixiecat
Try wearing an underwire bra...... While it doesn't generally set off the metal detectors, if you're wearing something that does and need to get the pat-down...
That's it, sign me up for TSA school!
The Barry
17th January 09, 08:59 PM
Flown kilted a bunch. Utilikilt Survival is good, but I found the USA Kilt Casuals more comfy on a long flight - like San Diego to Maui. Wore a kilt pin with double clasps on the back rather than the kind with the long stick pin. Took it off to go through security, put it back on once aboard the plane.
Comfy, very very comfy....and worth whatever hassles the Jr. G Men at TSA decide to throw your way. You can pretty much expect to be wanded just because you're "different." No big deal.
And, I've found a travel vest more comfy and easier in airports than a sporran or cargo pockets. Holds a lot more. Usually toss it in the overhead bin after boarding.
10th February 09, 11:46 PM
11th February 09, 03:15 PM
Loads of kilties flying to France this weekend. I would suggest no SD and no kiltpin if you are taking pop them in your hold luggage, if you don't have hold luggage I wouldn't bother, not worth the risk/cost of losing
15th June 09, 09:50 AM
With the rod in my leg and the silver woven compression stocking on, I get the "royal treatment" regardless of what I wear....so when I fly next in August, I just might wear a UK Workman's for the heck of it. The snaps alone on that thing might make the metal detector overheat!..
15th June 09, 01:35 PM
I have quite a few friends in the Tartan Army and they neverhave a problem. Although you should remove your sgian dubh (obviously) even if it is a dummy one and kilt pin also.
If youre wearing boots like timberlands you will probably be asked to remove them to put them through the scanner.
That's all I think
By Randy in forum Miscellaneous Forum
Last Post: 28th August 06, 01:29 PM
By TechBear in forum General Kilt Talk
Last Post: 23rd May 06, 10:46 AM
Last Post: 18th May 06, 10:22 AM
By longshadows in forum General Kilt Talk
Last Post: 6th March 06, 08:11 PM
By MtnBiker in forum Kilt Advice
Last Post: 1st September 04, 06:07 AM
