Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
    29th December 07
    KENT WAQ
    I own a "number" of KILT, ( "synthetic, TANKs, lighter weight wool ) & wear them almost daily for ALL types of occasions, I can perhaps "cast" a little light on the subject.
    Before I start, let me say that IMHO, putting 1 or more good synthetics in your closet, is a VERY GOOD IDEA, BUT the ?? was ( as I understand it ) Owning only a single Kilt as regular attire.
    The above comments pertaining to "wool " are spot on, but Perhaps the following will be of assistance.
    1. The quality of the material may be a consideration. My wool kilts are all of "good" quality, but there is a difference between them ( tightness of weave, finish,etc..) My "issue" regimentals & my one "Strome') are the best & EASIEST to keep clean. ( note - there maybe 1 more, see below)
    2. "Protective finish" - I recently got a TANK that has the wool protected with a "finish" It does change the "feel". As to how well it will work & MORE IMPORTANT, how long will it stand up ????
    3. PROTECT your KILT with a "KILT APRON". I took a "page" from the REAL PROs, the KILTED Regiments. They wore Kilt Aprons to protect their Kilts.
    Puffer
    26th February 08
    Ottawa, Canada
    I should like to have a 2nd kilt for day-to-day and keep the first for more formal occasions... A Family and a District Tartan respectively. I'm a bit leery of Polyviscose because of its fragility; but, I suppose that the material's inexpensivity may make it somewhat 'disposable' and therefore a good choice as a 3rd kilt, for 'mucking about'. ;-)
    16th January 06
    London
    Quote Originally Posted by Fit2BKilted View Post
    I don't think I would ever have thought of a pv kilt being fragile......
    7th February 09
    South Houston, Tx
    I only have one problem with PV kilts. I don't wear synthetics if I can avoid it. I have a nasty habit of getting close to fire. I've set a few shirts on fire, and have had to throw away more than I few that just had small burn holes from slag or embers. If you don't have that problem, then go for a PV kilt if you like.
    21st November 06
    Margaritaville
    Yesterday I piped a Memorial Day service in a very heavy downpour. This is known as Field Expedient Kilt Laundering; FEKL. This is why, when the sky opens up and heavy rain starts to fall, you might hear a piper mutter under his breath; "Oh sh*te..."
  1. Salt Lake Scots played last night
    By mbhandy in forum General Kilt Talk
    Last Post: 12th March 07, 12:39 PM
  2. So, how do you handle it?
    Last Post: 21st January 07, 08:32 AM
  3. Outdoor, rough use socks?
    By RoosterCodburn in forum How to Accessorize your Kilt
    Last Post: 7th November 06, 11:57 AM
  4. You guys are rough!!
    By Mike1 in forum Contemporary Kilt Wear
    Last Post: 3rd October 04, 06:31 AM
