Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
    Semiomniscient is offline Membership voided at member request
    22nd April 08
    N/A
    Depending on how much longer it is than you want it. Perhaps a temporary solution is to wear it higher than you normally would and wear a waistcoat/vest. It might not be the best as a permanent solution, but it might be better than trying to rush a job. (I note you say it is URGENT in the subject... so I assume you want to do something relatively quickly.)
    I am wearing an eight yard Grey Stewart kilt right now, and it's hemmed. It's one of my nicest kilts and since it's made from lighter cloth, the hem adds a bit of weight and swish. I did the hemming by hand. My Modern MacNicol is hemmed which I did by hand. My Lindsay 6 yard is hemmed, which I did by hand.. I could go on.
    7th September 06
    Tallahassee, Florida
    7 Post(s)
    Thumbs up Brilliant!
    Quote Originally Posted by Dixiecat View Post
    Suspenders can also aid in 'supporting' the kilt so that your abdomen doesn't go on strike. I believe some of the military kilts come with suspender buttons already sewn on due to the heavy weight of the kilt.
    Quote Originally Posted by BobsYourUncle View Post
    I agree about suspenders. I wear suspenders with my military weight kilt, and it was such an improvement in comfort that I had suspender buttons installed in my lighter civilian kilts. I still wear a kilt belt, but I no longer depend on it to hold anything up, and I no longer depend on the kilt straps, either. Suspenders all around! Cheers!
    Doh! I shoulda had a Guinness...
    Suspenders- What a good idea. My Dad had suspender/bracer buttons put on his new kilt, too. It's his first so I have to give kudos to 'im for that! I've never run into this, though? Somebody's been holdin' out on me!!! :P
    Thanks so much for the suspenders tip!
    Here's tae us, Whas like us... Deil the Yin!
    4th February 10
    Edinburgh
    Obviously lighter weight fabrics take well to hemming, my own kilt is hemmed as well, but could one convincingly hem a regimental weight kilt? Is it worth getting an ex-military kilt and shortening it to a more civilian friendly length?
    14th August 07
    Halifax, NS
    Quote Originally Posted by guitarmatt View Post
    Yes.
    Length isn't the issue. It's the fell. You can lengthen the fell, but shortening the fell is not possible if the pleats have been cut to reduce bulk. You might be about to shorten the fell by about 1" if you really were careful and reinforced the cut section in the back, but I've only ever speculated about that in my head so not sure if you'd really want to do that.
    4th February 10
    Edinburgh
    Yes.
    Good point, I'll keep an eye out for fell length as well as over all length.
  1. Urgent: Good pic of kilt 'to stripe' needed!
    By Nick Fiddes in forum General Kilt Talk
    Last Post: 8th September 08, 11:11 AM
  2. Wedding Kilt help please urgent
    By frankreid in forum Kilt Advice
    Last Post: 22nd August 08, 02:27 PM
  3. adjusting a SWK standard kilt??
    By Hachiman in forum DIY Showroom
    Last Post: 6th August 07, 06:05 PM
  4. Moving/Adjusting straps
    By David White in forum Kilt Advice
    Last Post: 21st May 07, 09:25 AM
  5. adjusting size
    By Jerry in forum Kilt Advice
    Last Post: 21st April 05, 01:03 PM
