Results 21 to 30 of 38
  1. #21
    25th May 06
    Kitchener, Ontario, Canada
    I only put loops on a kilt if a customer insists, and even then I will still try to dissuade them. That said, if someone's waist size is bigger or equal to their hip size, sporran straps will help the sporran stay put.
    Owner/Kiltmaker - Keltoi
  2. #22
    22nd November 07
    US
    Quote Originally Posted by The Barry View Post
    My tank doesn't have belt loops, but my SWKs do. I haven't "needed" them. I will use them on my SWKs to keep my belt in place, but that's the only real benefit. I also don't put my sporran strap through any loops, as I like to be able to shift my sporran to the side in the restroom or while driving.
    On the Stillwaters, there is no rise, and the kilt tapers all the way to the top at the waistband. It does kind of allow the belt to slide up.
    Didn't have that problem so much after I put a stabilizer in mine, and the problem went completely away when I sewed the waistband on while stretching the top slightly for a rise, after cutting out all the extra pleat materiel, etc, etc, hair canvas, bla, bla, bla.
    So I think the rise is part of the issue with the belt riding up. I didn't bother to put the loops back on.
  3. #23
    31st August 10
    Lodi, California, U.S.A. (Northern California)
    Belt loops are superfluous, belts and bucles
    Beelts loops are not a traditional part of a kilt. In addition, a pipers kilt should have only ONE waist belt on each side; two in total, while a Dancer's kilt has the afrementioned two, plus and additional belt and buckle on the Upper apron, right below the right side waist belt and buckle.
    Unfortunately, a great number of pipesr wear dancers kilts, and don't even know it.
  4. #24
    17 Post(s)
    From my first kilt, made by my Grandmother when I was a teen back in the 1970s, to the various Army kilts I wore in the late 70s, to the kilts I've had made for me from around 1980 to a few months ago, none have had loops.
    Kilts aren't trousers, and I don't think the right course is to try to get an improperly fitting kilt to stay up by cinching a dirk belt around it. Properly fitting kilts stay up on their own.
    These belts were called "dirk belts" in the old days and were worn to support a dirk, but rarely otherwise.
    I rarely wear a belt when I'm out piping:
    though I know it's the modern tradition to wear kilt jackets open with a dirk belt showing.
    I especially dislike it when I see belts peeking out from under waistcoats (vests). It looks slopply to me. You don't see that in the old days.
    End of rant.
  5. #25
    The following photo shows what happens when you wear a belt through loops on the back of a kilt:
    As I wrote in TaOK, every time you bend or sit, the belt pulls up on the loops, and this distorts the horizontal tartan line across the back of the kilt. If you wear a kilt this way long enough, the bottom edge of the kilt actually pulls up permanently and doesn't lie straight.
  6. #26
    3rd July 09
    Canada
    OK I see it now so I believe it. I can always switch to suspenders I guess, they have the military's imprimatur. But still, does anyone argue about belt loops on trousers on a pants site somewhere? ... this shows that kilts are special I guess.
  7. #27
    20th July 05
    Philadelphia
    Are there actually pants sites to provide a forum for discussion of such intricacies?
    anyway, pants dont have that extra couple of pounds of fabric at the back that pulls your butt down and makes you stand more upright with shoulders back....
    Daft Wullie, ye do hae the brains o’ a beetle, an’ I’ll fight any scunner who says different!
  8. #28
    10th December 07
    Seven Lakes West, North Carolina
    Great question and great replies. Once again I've learned something new.
    Thanks
  9. #29
    17 Post(s)
    There's a kilt I see here at every Games that's far worse than that one.
    The back looks like the Golden Gate Bridge, or an inverted McDonald's Arches.
    I'll be seeing it in nine days at the Queen Mary Games, unless the guy has got a new kilt since Pleasanton. I'll see if I can snap a photo of it without making him too suspicious as to my motives.
  10. #30
    13th November 10
    Tampa bay, FL
    Is this an issue because the pleats are independent from each other or is it the fabric actually stretching? If the pleats are sewn together at the top, similar to utilikilts, does the same thing happen?
  1. What Are the Two Loops on Kilt Belt?
    By Galb in forum Kilt Advice
    Last Post: 6th May 08, 01:13 PM
  2. Belt through loops or over?
    By Standard in forum Kilt Advice
    Last Post: 7th February 08, 10:28 AM
  3. Belt Loops
    By SnakeEyes in forum How to Accessorize your Kilt
    Last Post: 31st January 07, 09:25 PM
  4. Belt Loops on Kilts - Why?
    By MACKAY in forum How to Accessorize your Kilt
    Last Post: 24th July 05, 10:11 AM
  5. UK Belt Loops
    By Galant in forum Contemporary Kilt Wear
    Last Post: 4th March 05, 02:34 PM
