Results 1 to 10 of 22
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    Tartan of the month - December: What do you see?
    Very Christmas colours Thoughts and ideas?
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    Re: Tartan of the month - December: What do you see?
    Peter,
    It's hard to tell due to the image size, but this looks like a plain weave to me. Can you verify?
    2nd January 10
    17 Post(s)
    Peter,
    Matt,
    Replaced the original image with a higher res one. Should'nt be too difficult for you as you have a record of it and so better keep your powder dry for a while.
    21st March 11
    It almost looks like there are holes around the edges - as if is were once sewn into a piece/garment, and the stitching was removed - instead of a random scrap being cut out.
    The symmetry also says this.
    Any chance of a closeup on the two holes near the top left corner?
    6th February 10
    U.S.
    Muirhead?
    2nd January 10
    17 Post(s)
    Quote Originally Posted by creagdhubh View Post
    Muirhead?
    Nope
    25th December 08
    Lotus Land
    Attractive sett. Excellent colours. Very Wilsons looking. Wonderful balance. It looks like five colours to me, but there could be a Yellow as well as a pale Green. Herringbone edge up top which appears to end in the Light Blue rather then the Dark Blue therefore breaking the sett right at the edge. Early to mid 19th century then? Have I got that right?
    Are those staples I see in the top right?
    It looks like there's some kind of stitching around the outside edge of the piece which I can't imagine a use for. The buckling of the fabric in the bottom corners is almost certainly caused by this.
    It also looks like it might be a lighter weave and not that large a piece. May we have the dimensions?
    There are also some interesting little 'jigs' in the vertical weave. Not quite a full herringbone turn around, but perhaps just for one thread and then back to the established twill weave. I'm not sure if this is intentional or a function of the loom or something else.
    2nd January 10
    17 Post(s)
    Quote Originally Posted by xman View Post
    Yellow yes but pale green?
    Herringbone - really?
    Early to mid-C19th. Why do you think that is the case?
    No
    Agreed
    From what I recall it's about 6x8"
    Ah. So what might it be?
    25th December 08
    Lotus Land
    This is my cognitive deficiency with the overlap which I believe I mentioned in an earlier thread. Yellow it is.
    AH, NO. It is the 'jigging' issue again although there are a few treads which run back the other way and then return. I should have looked closer.
    Mostly my mistaken herringbone interpretation.
    I've not a clue.
    14th January 11
    Langley, BC, Canada
    From the matching angles of the cuts on the sides, and the creasing across the middle, it looks like it was folded and stitched together, but not as a pocket or pouch as it looks stitched on all 4 sides. But it isn't stitched along the fold, and as the fold isn't a tight crease it may have been folded around some other fabric before being stitched down.
    We seem to be looking at the inside surface; from the holes/tears the top, darker part of the sett, with the tidy edge, looks like it got most abused, probably on the other side of the cloth.
    A double-thickness patch for the top edge of a worn or torn kilt apron, or a repair on a piece of upholstery?
  1. Tartan of the Month - August: What do you see?
    By figheadair in forum The Tartan Place
    Last Post: 27th August 11, 08:39 AM
  2. Tartan of the Month - May. What do you see?
    Last Post: 4th June 11, 05:41 PM
  3. Tartan of the Month - April
    Last Post: 29th April 11, 07:41 PM
  4. Tartan of the Month - March
    Last Post: 28th March 11, 01:13 PM
  5. Replies: 7
    Last Post: 28th December 07, 04:11 PM
