7th August 12, 12:33 PM
#21
7th August 12, 04:20 PM
#22
Woodsheal - I am aware of your expertise, so am somewhat hesitant to ask this. How accurate are the sheaths of your two dirks? That is to say, was there a lot of fancy leatherwork? And for that matter, were the belts of a similar standard?
7th August 12, 04:30 PM
#23
Of the two sheaths, I would say the knotwork on the first one (McClain) is rather fanciful and "interpretive", though the configuration of the sheath itself is accurate. The sheath with separate frog set-up is based off an original or two. The simple crossed lines and dots motif of the second sheath is correct, and commonly seen on period sword and dirk scabbards.
Brian
7th August 12, 04:37 PM
#24
Thanks, Brian, for the swift reply. A leatherworking friend of mine has promised me a new belt and I must admit that I am torn between the two designs.
7th August 12, 04:42 PM
#25
If you're after a Jacobite period-looking belt, I'd go with the simpler design. It shows up on shoulder-belts (baldrics), too. It's a nice alternative to the dense knotwork appearing on so many present-day belts!
Brian
8th August 12, 03:10 AM
#26
I think it is the simplicity that attracts me. Although very pleasing the dense knotwork has almost become a byword for any Scottish leatherwork - almost a pastiche of itself.
I notice that the clip has a matching saltire - was that a period feature or happy coincidence?
And what material and shape should a buckle be?
Thanks
8th August 12, 08:33 AM
#27
Thanks
I wonder if all those Xs were meant to be saltires, or were just an easy way to incise a decorative touch...?
Anyways, the "double-D" style of buckle was most common on 18th C. belts. Various widths available here (scroll down):
http://www.thequartermastergeneral.c...tegory=buckles
If you need a UK source, Todd here could fix you up with a proper period buckle:
http://www.foxblade.co.uk/
Brian
8th August 12, 09:45 AM
#28
Thanks, Brian. Todd at Foxblade isn't far from me.
3rd September 12, 04:04 PM
#29
Here is my first dirk - an ebay special....lol
3rd September 12, 06:43 PM
#30
