23rd December 12, 02:54 PM
#21
 Originally Posted by Domehead
As for the tartan. I do like your take. Of course, I like the additional "pink". As well, I like the black guard stripes. The only thing that may come to mind is border check?
I'm relatively new to the tartan design game - what's a "border check"?
Stìophan, Clann Mhic Leòid na Hearadh
Steven, Clan MacLeod of Harris
Dandelion Pursuivant of Arms
23rd December 12, 07:52 PM
#22
Someone else may know the entire history, but...
It is smaller black-and-white check tartan, indicative of untreated sheeps wool (both "white" & "black"). The height of its popularity was the early to mid 18th Century, coinciding with the influence of Sir Walter Scott's writing & wearing. Traditionally it's limited to the Border Region as, historically, few Border families had "named" tartans.
Familially, we always called it Shepherd's Plaid.
Re: the design, so far I'm the only one who referenced "Border check". I wouldn't worry about that being on the front of any critique. I can be goofy that way.
24th December 12, 03:51 AM
#23
No worries. My family story puts us as from the Outer Hebrides anyway (hence the surname), which is about as far from the Scottish Marches as you can get!
24th December 12, 11:08 AM
#24
I'm happily surprised that no one seems have have blinked at the pink stripe
P16 G56 W36 K8 W4 K32
27th December 12, 08:51 AM
#25
Pink is just light red. White, on the other hand, is hard on the eyes.
Kenneth Mansfield
NON OBLIVISCAR
27th December 12, 11:02 AM
#26
I'm guessing you'd have the pleats bringing forward the pink stripe on the green which would minimize the white in the back.
27th December 12, 01:06 PM
#27
Interesting. Another disappearing post.
To repeat:
My go at your idea with a consideration for pleating options...
28th December 12, 06:11 PM
#28
To repeat:
I like it! I might play with this design...
1st January 13, 02:55 PM
#29
Notes to fledgling tartan designers:
1. 240-340 threads including all pivots will yield a tartan about 6-8.5", ideal for kilt pleating
2. Pivot points (and all pleats ideally) should have a clearly identifiable block of at least 32 threads or about 3/4"
3. Central stripes larger than 12 threads will overly dominate the fell.
Break these 'rules' as you need to. I'm sure there are other considerations.
2nd January 13, 04:25 AM
#30
Beware being too dogmatic especially without clarification.
1. 240-340 threads including all pivots will yield a tartan about 6-8.5", ideal for kilt pleating - this assumes a modern heavy weight cloth set at 40 epi. Different weights will give proportionally smaller or bigger setts.
2. Pivot points (and all pleats ideally) should have a clearly identifiable block of at least 32 threads or about 3/4" - dion't confuse pivot and pleat. If one worked on a minimum of a 32 pivot count then many traditional tartans; Black Watch, MacDonald, MacDougall, Gunn, Royal Stewart etc, etc would not comply with the 'rule'.
3. Central stripes larger than 12 threads will overly dominate the fell. Not sure what you mean by the fell but there are numerous traditional patterns that don't follow this concept: MacAlasdair, MacColl, MacDonald of Sleat, Menzies, Sinclair to name but a few.
