Originally Posted by
Friday
Does anyone know where I could obtain a pattern for square topped castellated hose? The pattern in Veronica Gainsford's Knitting Kilt Hose & Knickerbocker Stockings is for pointed tops.
I think you could follow Gainsford's pattern, except for the deceases, and bind off every other point. In other words, if your sock ends up being 72 sts at the cuff, you'd divide 72 into an even number (8X9, 6X12, 4X18) and figure out which would make the best-looking castle. I think 12 castles of 6 sts would look nice.
Rnd 1 of castles: *K6, BO6*.
Rnd 2: K6, turn, with DPN pick up 6 sts at base of just-worked sts. Divide these 12 sts on to 3 DPNs.
Rnd 3: Join 6 knitted sts and 6 picked-up sts into round. Knit around for 6 rnds. Graft (Kitchener stitch) closed. Cut yarn. Weave end in. Attach yarn to next set of 6 sts and repeat Rnd 2.
I've never tried this pattern, but it should work. The knitted-in-the-round castles should stand up nice and proud and not curl they way they would if a careless knitter had simply knitted them flat and hoped for the best.
--dbh
