4th November 04, 09:12 AM
Want help with material weight
Could you explain the weight of fabric? Is that ounces per liner yard? If so, how do you compare when some fabric comes in wider rolls then others.
Also how can I find out the weight if it is not marked on the roll without actually weighing it. I see a lot of the rolls do not tell the weight, or I at least can't find it. Is it coded some way?
Finally.. what weights are good for the various kilts, such as the Amerikilt Cotton, Wool and PV light weight for summer and heavier weights for winter?
What weights does Bear and USA Kilts use and why?
Thank you!
Please be as detaild as need be.
