Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 74
  1. #31
    billmcc
    David White,
    I really like the dirk in your picture! Is it a custom blade?
  2. #32
    cormacmacguardhe's Avatar
    cormacmacguardhe is offline Oops, it seems this member needs to update their email address
    26th September 05
    Maple Falls, Washington. USA
    All I have right now is a battle axe. Working on making my own targe.
  3. #33
    billmcc
    Quote Originally Posted by cloves
    what are the usual diameters of targes?
    Usually 19 to 20 inches in diameter.
  4. #34
    27th March 06
    Ferintosh, Dumfries, Scotland
    Quote Originally Posted by cavscout
    If you need two claymores at a wedding they might ought to close the bar a bit earlier
    nay... we use them tae get TAE the bar! HA!
    really.... this is hae they arr used...
  5. #35
    macwilkin is offline
    Retired Forum Moderator
    Forum Historian
    22nd June 04
    targe...
    The Tartans Authority has a nice article about the Targe here:
    http://www.tartansauthority.com/Web/...s/Weaponry.asp
    Happy Reading! :mrgreen:
    Todd
  6. #36
    6th September 05
    Stanardsville, Virginia
    Quote Originally Posted by billmcc
    David White,
    Yes it is, The dirk was made by Michael "Tinker" Pearce.
    Thanks
    Clan Lamont!
  7. #37
    6th September 05
    The one I made is 18". Has anyone ever seen the portrait of Lord George Murray ca. 1740? His targe is very small. I'd like to make one that size.
    Clan Lamont!
  8. #38
    3rd January 05
    Detoit, Michigan USA
    Here is Lord George Murray.
    [B]Paul Murray[/B]
  9. #39
    3rd January 05
    Quote Originally Posted by I M Kilted!
    Basket hilts are cool! I was desgining one in my head, here are the materials: Damascus Steel Blade, Ebony Handle, Blued Steel Basket and Fittings with a Black leather sheath with Blued steel fittings.
    That sounds like a stunning sword!! I would love to see it when it comes about!
    [B]Paul Murray[/B]
  10. #40
    8th June 04
    Port Crane, New York
    Quote Originally Posted by Iolaus
    What do you do for the edge, just stretch the cowhide around?
    I rasp and sand the edge of the wood so it's rounded and smooth. The front piece of leather I cut so it's a few inches greater in diameter than it needs to be. I then make 1 inch triangular cuts around that diameter, so that it ends up looking like a big circular saw blade.
    I then thoroughly wet the leather all around its diameter to make it pliable, then begin pulling it over and nailing it to the back. I do this by nailing at opposite sides of a "clock face" if you follow me. I.E., I'll pull the leather over and nail it at the 12 o'clock position, then 6 o'clock, then 9, then 3, etc. This will result in it being more uniform and not bulging or bunching in spots.
    When it's all nailed around the back, and the leather has dried and tightened into place, I trim off the points of the "sawblade" I mentioned earlier.
    The thinner back piece of leather can either lie under, or go over the nailed back front piece. The former is easier; the latter is the method seen on most originals. I also put padding - usually wool fabric - under the back leather, too, doubly thick under the arm area.
    Most originals are 19" in diameter....
    Brian
