Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
  1. #31
    Quote Originally Posted by Stewart Rendall View Post
    It's never really been bad enough for me to consider flipping the cloth in the other direction. If I encountered cloth where the tucked threads were noticeably more apparent on one side then I'd probably have to think about it.
    It would feel odd making it with the twill going the other way though. It's a tricky one.
    I, too, would feel odd making it with the twill running the wrong way, and I haven't yet encountered a piece that was bad enough on the "right" side that I would consider reversing it. Hopefully I won't in the future!!
  2. #32
    24th January 08
    It's amazing, much of the time the best I can do here is read and learn, then read again in appreciation. One of the small joys that make for a happy life.
    Thank you all.
  3. #33
    Quote Originally Posted by turpin View Post
    Typically the first pleat (left side) has a bit of a tuck-up hem to prevent the corner of the pleat from peeking out from under the aprons and messing up the uniform line. I think this is also done with the right-hand corner of the under apron.
    And also with about 9" of the lower edge of the underapron. If you see this, it means that your kiltmaker knows what he/she is doing!
  4. #34
    When I was in Sidmouth (England) last year - at the Folk festival where the percentage of kilts is far higher than seen everyday, I offended a man by pointing out that his kilt was made up inside out - that is with the twill line running the 'wrong' way.
    His kilt was made - I think, by Hector Russel - and he declared that such a noted kilt maker would not get it wrong - but the twill line ran from left hip to right knee....
    Perhaps it was one of the fabrics from the firm whch has the right side on the 'wrong' diagonal and the inside was not presentable.
  5. #35
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    I have, in the past, made kilts where the twill line ran the opposite of what is normal, because I was using cloth from a mill that was simply made with the twill line running that direction on the right (good) side of the fabric, as Barb has described.
    To me, it was a fairly easy decision. Why is it customary for the twill weave in a kilt to run from the left knee up to the right hip? Because that's the way the twill will run if you make the kilt with the good face of the fabric on the outside, as it should be. No other reason, really.
    So what do you do if you encounter a peice of fabric where the good face has the twill running the opposite direction? Well, in my opinion, you still make it with the good face on the outside.
    Granted, much of the fabric from the better mills these days is good enough that you can hardly tell a difference between the good face and the reverse side; but that's not universally true. Sometimes you do get knots and thread ends and the like as Barb describes on the reverse side of the cloth.
    To me, it's most important that the kilt be made with the good face on the outside, as intended. Even if that means that for this particular kilt the twill runs counter to what is "normal." How many of us pay attention to the direction the twill runs in our denim jeans? Why should it be that big of a deal in a kilt, really?
  6. #36
    aye Matt, I too have seen kilts from some of the most respected Scottish and N. American houses where the fabric was very evidently inside out. The Twill was not only running from Left Hip to Right Knee but the frayed edges of the turned Selvedge was on the outside.
    Not only have I had to make Kilts with the Twill running the "Wrong" way to keep the good side of the fabric out but I actually ran into a piece of fabric where on on Selvedge edge the turned selvedge was on the opposite side from the other Selvedge. The frayed edges were so evident that that one kilt had to be made with the Twill lines running in one direction on one half of the Kilt and running in the other direction on the other half. Luckily we had just enough fabric to offset the join so that on the outside the change in Twill direction was in the middle of the back. It looked OK and I doubt too many people would even notice.
    On a side note; All of my Poly/Cotton and 100% Cotton fabrics have the Twill lines running the opposite from Kilt Wool. Not sure why that is or which is "correct".
  7. #37
    Having slept on this, I think I have the answer, at least as to why the right side has the twill the wrong way for kilting.
    For most cloths there is a difference in the warp and the weft, with the warp being the stronger, so for most patterns for 'normal' clothing the pieces are cut out along the long axis of the cloth. When worn the garments have the strong threads vertically on the body.
    If that was done with the 'aberrent' tartan cloth then the twill would run the traditional way, upper right to lower left.
    Kilts, however are made with the weft vertical, which rotates the direction of the twill into the mirror image.
    ( War[u]p runs up and down the loom and you weave from weft to wight - yes, painful, but now try to get it wrong.)
    If you were to make a kilt from a twill pinstripe - where the pattern would dictate that the cloth be cut and pieced selvage to selvage then you would get the traditional slope if the cloth was woven in the modern manner.
  8. #38
    24th March 08
    the Highlands of Central Oregon
    As I mentioned, I received a replacement kilt for the rental. the replacement was far less noticeable. I didn't look which way the twill was running (and frankly I wouldn't care) but a a person wearing the kilt, I would prefer the less noticeable selvage.
  9. #39
    27th August 07
    Woonsocket RI, USA
    My newest kilt, an IoS tartan kilt, 13oz tartan from Marton Mills has a tucked selvage but it's tastefully done right at a transition line in the tartan so it's hardly noticeable
  10. #40
    24th March 08
    Just before I returned the rental kilt (s) I looked again and sure enough the kilt that looked so awful and "torn" up had the twill running from the left hip to the right knee.
