Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 85
  1. #31
    14th June 10
    Cali
    Day 17 of the No Legs Strength Program
    Warm up
    Exerbike
    Shoulder Pre-hab
    1x5 Half Get Ups
    Seated Press
    1x10x45
    1x3x65
    1x2x75
    6x1x105-115-120-120-125-130
    Batwings
    1x5x27.5 held for 10 seconds
    Seated Leg Extensions
    1x15x20
    Prone Hamstring Curls
    1x15x20
    Hanging Knee Raise
    1x10
    Short Range Chins
    1x10
    Ab Wheel Rollouts
    1x5
    Seated DB Curls
    2x10x22.5-32.5
    I didn't get enough warmup lifts in the Seated Press and that held me back in the early going. Next time I do the six singles workout I will make sure I get in a few more warmups before the singles.
  2. #32
    14th June 10
    Cali
    Day 18 of the No Legs Strength Program
    Warm up
    Exerbike
    Shoulder Pre-hab
    1x5x5 Half Get Ups
    Seated Press
    1x10x45
    1x3x65
    1x10x85
    Batwings
    1x5x15 held for 10 seconds
    1x15x10
    1x15x10
    Hanging Knee Raise
    1x10
    Short Range Chins
    1x10
    Ab Wheel Rollouts
    1x5
    Seated DB Curls
    1x10x15
    This is the tonic workout that follows the six singles day.
    I'm growing concerned that the PT recommended leg curls are irritating my right knee.
  3. #33
    leg curls are harder than the extensions? It's usually the other way around, for me.
  4. #34
    14th June 10
    Cali
    Day 19 of the No Legs Strength Program
    Warm up
    Exerbike
    Shoulder Pre-hab
    1x5x5 Half Get Ups
    Seated Press
    1x10x45
    1x3x65
    1x2x85
    2x5x105
    Batwings
    1x15x25
    1x15x15
    Hanging Knee Raise
    1x10
    Short Range Chins
    1x10
    Ab Wheel Rollouts
    1x5
    Seated DB Curls
    2x10x22.5-32.5
    March 27, 2013
    Day 20 of the No Legs Strength Program
    Warm up
    Exerbike
    Shoulder Pre-hab
    1x5x5 Half Get Ups
    Seated Press
    1x10x45
    1x3x65
    1x2x85
    1x5x105
    1x3x115
    1x2x130
    Batwings
    1x5x22.5 held for 10 seconds
    1x15x25
    1x15x15
    Hanging Knee Raise
    1x10
    Short Range Chins
    1x10
    Ab Wheel Rollouts
    1x5
    Seated DB Curls
    2x10x22.5-32.5
    Yes, it's the leg curls that affect my gimpy knee. It must have something to do with my kneecap because the roller that supports my leg just above the knee seems to prevent my kneecap from moving properly in some way. Runner's knee I believe it was called. Anyway, the various leg strengthening rehab moves and stretches are supposed to help with this.
    In other news, I tried out a tip in the chins and found it helpful. Therefore, I share it here. When chinning, bend your knees a bit and cross your ankles behind you. Then hold your body rigid while doing the chins. Any body movement allows the applied strength to "leak" out of the chin. Please do not let me see anyone here do kipping pull-ups. We are throwers who value our shoulder joints and the heavy athletics provide more than enough dynamic work.
  5. #35
    14th June 10
    Cali
    Here's today's training tip.
    In the weights for distance, the left side of the body has a significant role to play. Left-handed throwers, it's the right side of the body.
    At the beginning of the first spin, the left heel should be turned to point to the weight and the left arm is used to help with the rotation. In the second turn, the left arm is again used to facilitate the turn and release. Throw with your whole body.
    Check it out in this slo-mo from Jake Sully.
    Also notice that the steps are "paired" as if Jake's shoelaces were tied to together. You cannot step through the turns and expect to throw well. Jim McGoldrick once told me to "hear" my feet. They should sound like "bump-bump....bump-bump" and not "bump...bump...bump...bump".
    So. Listen to your feet when you throw.
  6. #36
    14th June 10
    Cali
    Now that I've returned from my 1800 mile/four day road trip across SoCal and Arizona to visit family and friends, it's time to resume posting on my training log.
    Yesterday I had a follow up appointment with my physical therapist. He noticed right away that I was no longer walking with a limp and his examination my knees produced no pain. He gave me a new set of exercises to re-hab my knee and suggested I see him again in about a month.
    April 8, 2013
    Day 21 of the No Legs Strength Program
    Warm up
    Exerbike
    Shoulder Pre-hab
    1x5x5 Half Get Ups
    Incline Press
    1x10x45
    1x3x95
    1x2x135
    2x5x145
    18" Snatch Grip Deadlift
    1x5x135
    2x5x225
    1x15x25
    1x10x10*
    Hanging Knee Raise
    1x10
    Short Range Chins
    1x10
    Ab Wheel Rollouts
    1x5
    Seated DB Curls
    2x10x22.5
    The PT gave me the okay to add the deadlifts back into the routine so I did. The bad news is that I had to stop the leg curls at 10 reps with 10 lbs do some joint issues. I immediately scratched the leg curls from my routine which turned out to be a great idea as I woke up this morning with a great deal of stiffness in the knee and some discomfort when walking. Damn!
  7. #37
    The other thing I notice about Jakes video is a principle that I picked up from actually watching Andy Wooster, and then teaming that up with a comment or two I got in a message at NASGA from Don Stewart. Let the hips drive the weight. Where your hips go, that's where the weight goes. See how Jakes hips rise at the back of the trig, before he starts his first turn? Then his hips drive the weight to the low point a little bit behind him and off his right side.
    When I started doing that, I put 3-4 feet on my LWFD throws.
    That's great news about your knees....no pain is *good*. Will you be at Woodland?
  8. #38
    Marty and I were discussing the overall quietness of your log, this Sunday. We both hope your knees are behaving themselves, and that we'll be seeing you at Woodland.
  9. #39
    14th June 10
    Cali
    Yes, my log has been quiet.
    I have a backlog of at least 10-12 workouts to post.
    Left knee is as good as it's ever been. Right knee concerns me in that it's still stiff although there isn't much pain to speak of. Growing concerned that the way it is now is the way it will be from here on out. I need to go back to see the sports doc.
  10. #40
    14th June 10
    Cali
    In my never ending search for wheat in the chaff, I came across this nugget on the NASGA training forum.
    Quote Originally Posted by JSully
    On hammers don't let your upper body take over. Keep the ball on the right side. Two cues I use are to pull the hammer UP [to] me, not across me. As soon as the ball gets "light" twist your torso and catch the ball. That will let your hips take over and work the weight shift like Sean is talking about.
    In other words, pulling on the hammer is NOT like swinging a baseball bat.
    I've been preaching the gospel of the "pull is UP, not around" and the "Highlands Hula" for many years now. Unfortunately I got old before I got better at throwing the hammers but I'm holding my own.
