Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 64
Thread: Hand made kit
  1. #31
    10th August 13
    Australia
    So I have been busy tonight and I have yet more pictures.
    Also a special thanks to "Downunder Kilt" for the pictures. when I initially set the pin on my kilt pin, I set it 90 degrees out of whack - then glanced across the workshop to see the picture on the screen, and managed to rotate it more appropriately while the solder was still hot.
    Below: the whole show as it stands, less the buckles and a couple of items to come.
    Treskle design kilt pin (before I fixed the angle of the pin)
    Solder to white-metal bonding
    Treskle before fill
    Crane design - not as happy about this one - lost alot of detail, but it does still hold that "ancient feeling"
    It comes down to the surface viscosity of the white metal I'm using - budget metal - budget result.
    I need some pewter I think
    Treskle design fresh out of the mold
    Crane design during polishing - before fill
    Crane design with a new "experimental casting process - keeps the thickness down, and thus the weight.
    this one will likely go on the bride's sash.
    Back of the wolf pin - this was a test for the clip attachment - another pic coming as I'm at my attachment limit.
    ---If you are going to die - Die with your boots on---
  2. #32
    10th August 13
    Australia
    Last little picture here: the wolf pins from the front - to get around 10 images per post limit.
  3. #33
    10th August 13
    Australia
    Another work in progress - I will be making a Sgian Dubh as a gift to the piper (along with a decent bottle of Irish whiskey)
    as he will be taking time off work to make it to the wedding.
    He is a black powder shooter and kilt enthusiast, so I have tried to incorporate elements of this into the design.
    I had to laboriously retrace and rework the piper silhouette as I couldn't find it in vector format anywhere.
    I'm also interested to know if there is any particular protocol behind presenting knives in this regard EG: The British custom of handing over a coin when presented with a knife.
  4. #34
    30th June 13
    Coon Rapids, Minnesota
    Man the whole lot looks so great, if I wasn't married, I would be trying to get you to make a set for my wedding.
  5. #35
    10th August 13
    Australia
    I still have to post a pic of the one I'm handing to the piper - kinda screwed up the fill so have to re-melt and start again.
    however there has been alot of interest - and as a result I'm going to look at procuring some virgin metal, and making a few for sale>
    you guys will be the first to know
  6. #36
    10th August 13
    Australia
    Few more pics as promised:
    I need a little more work on my graphics, I had to hand carve alot of this one.
    after a thorough polish it looked good.
    Tried some better lighting, but this only shows up the screwed epoxy - I think the sub zero temp in my workshop messed with the curing.
    A couple more artsy shots for those who are fans of the tartan
    A slightly better pic after some repair - but I'm still not happy and will melt this one down and try again.
    A sample of the kit against a sash for artistic feel.
  7. The Following User Says 'Aye' to Dranoweb For This Useful Post:
  8. #37
    10th August 13
    Australia
    Melted down my attempt at the piper handle - and remade it. Quite happy I did, the results are much better.
    I took the liberty of using the laser to cut the blade seating, pouring gallery, and the guide holes this time.
    Very glad I did, and also progressed to using some graphite as a lubricant - this iteration is by far the best.
    Some reworking of the graphics was in order too - one can no actually make out the pipe, tassels and mouthpiece.
    The right hand mold half before casting
    No more alignment issues.
    A quick polish and the detail begins to appear.
    The blade is perfectly flat now, no funny angles.
    after a decent polish and cleanup - epoxy fill time - still setting at the time of this picture.
    Think the piper will be happy with this?
  9. #38
    15th August 12
    Tennessee, USA
    Quote Originally Posted by Dranoweb View Post
    I'd be quite interested to see some of your work too. I'm planning on making some leather punches with a variation of my casting methods soon.
    Here you go, mate. Here's one of the belts that I made a while back and posted to this thread:
    http://www.xmarksthescot.com/forum/f...-masses-79240/
    PM me if you get a minute. I have an idea to run by you. Your casting is looking pretty sharp. I love your Tree of Life design.
    The Official [BREN]
  10. #39
    10th August 13
    Australia
    For those of you still following this post - I'm up to the sheath stage.
    I'm interested in opinions again, as I feel it may be a little too thick.
    Some photos of the assembly stages - in case anyone has better methods.
    Anyway enjoy the pics - feel free to throw any comment my way as I take them all on board, and it all helps to create a better end product.
    The remaining parts laid out - and the dummy blade for the mini Sgian Dubh going to my nephew
    two prototype halves, out of the laser, sanded and epoxy ready.
    Clamped - waiting patiently for the epoxy to dry
    First look and test fit.
    Checking alignment - this shows the thickness - and what I'm not entirely sure about.
    does this look good to you guys?
    Detailing in the laser cutter after 1200 grit sanding
    Almost complete
    The design is a slight rearrangement of the knotwork splines used to make the handle.
    I just removed the pommel end and converged the splines to a single point - hoping this looks ok, as it's been a long day in the workshop.
    The prototype display with original handle design
    prototype displayed with piper handle design (this one is going to the piper along with a bottle of whiskey for his troubles)
    The sheath still needs some varnish - I'll probably go with spray on marine varnish - I'm considering staining the detail instead of relying on the laser burn to make it stand out.
    Another idea was to use epoxy and graphite powder to fill, but I would loose the sheen when I sand it.
    I tested this on some leftover epoxy fill and was unable to get a cleanly sanded finish - would be interested if anyone has ever worked with the stuff.
  11. #40
    25th November 11
    upstate NY near Syracuse are
    that is some great work!! i love the wolf pins!!
