16th May 06, 12:13 PM
#391
 Originally Posted by bangkok kilt
Ok, i know this one's risky, but I couldn't resist. . .
DON'T walk over the vents in yer kilt!
It'll go..been pulled before...and in this same thread!
no reason to give up the answer THE question.
you might want to edit the post, the mods probably will if you don't..
16th May 06, 12:23 PM
#392
No matter what you think - you will never look like Mel Gibson
So don't even think about trying...
16th May 06, 12:26 PM
#393
Good point. Hopefully the edit is acceptable procedure.
16th May 06, 12:27 PM
#394
yeah, that's pretty weak!
#395
DO follow this man's lead
Isn't that Nick's avatar from the Pub?
16th May 06, 12:31 PM
#396
Not sure, but that would make a good avatar wouldn't it?
16th May 06, 01:07 PM
#397
This post is one of the biggest I have seen in the past 2 years I have been on the forum.
There have been a lot of fun pictures on here, but I have to issue a warning here. No Nudity. This is a family forum.
Part of the mystic of the kilt is the "what's under it" question. Let's try and not provide that answer here ok, guys.
16th May 06, 03:55 PM
#398
DO mix leather with the kilt
I have boots like those for riding - and tey fit the same way - too wide at the top not to be conceled under a pair of jeans rolled in the 60's rocker style, of course
16th May 06, 06:06 PM
#399
I just noticed that picture of Sir Sean Connery...he's wearing a four in hand tie with the PC, I had heard this was a no-no, or did I hear wrong? Also the tie is in the same tartan that his kilt is and I've also always believed that this was wrong what gives? Matt?
Chris.
16th May 06, 11:11 PM
#400
The "rules" of ties as I've heard them...
A four-in-hand is fine with a PC.
A tie worn with the kilt should be one of these: solid color toning with the kilt, tartan of the same as the kilt but cut on the bias (i.e., 45 degrees "off" of the kilt's pattern), tartan of the wife's clan (also on the bias), a school tie (stripes), or solid black or grey depending on the color of the jacket or waistcoat.
Striped ties that are NOT school colors should be avoided.
If one is going to wear a tie of the same tartan as the kilt, best to get it from the same mill - otherwise, the colors don't quite match, and it looks odd. It's also painfully weird if the sett is of a similar pattern but different size.
