Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 51
  1. #41
    3rd January 08
    Illinois, USA
    4 Post(s)
    I also follow the trend that seems to be most prominent here, namely leaving the bottom button undone. One reason being that it just feels more comfortable, especially while sitting. I have a wool Filson vest that I wear almost the entire winter which has a straight cut bottom, with the way it hangs the bottom button closed is simply too constrictive for comfortable movement. Now, when getting all dressed up I generally follow the same rule, except at McMillan noted when the waistcoat has only 3 or 4 buttons, then they all get done up. Not sure why this is the cast, just the way that I learned to do it.
    Member Order of the Dandelion
  2. #42
    4th March 04
    Sonoma Co, CA
    Quote Originally Posted by JSFMACLJR View Post
    I don't quite follow your reasoning here. I, and many others, leave the bottom button of a waistcoat undone. What do you mean when you say "Highland tradition is much older than Edward VII"?
    Waistcoats are much older than the late King Emperor too.
    I simply meant that a custom originating in "civilian" dress doesn't necessarily translate into a change in the separate tradition of the way highland attire is worn. Some do--wing collars on formal shirts for example. Others--like, say, a blazer patch on an Argyll jacket, don't.
    If anyone wants to unbutton his waistcoat, (or wear a blazer patch) I'll consider that his business and none o' my own.
    "...the Code is more what you'd call 'guidelines' than actual rules."
    Captain Hector Barbossa
  3. #43
    17th December 07
    Staunton, Va
    Quote Originally Posted by Standard View Post
    I suspect there are two reasons for this. The first, at least as far as my waistcoats are concerned, is that the evening waistcoat is shorter in the front. The second, again looking at my waistcoats, is that evening waistcoats tend to be backless, allowing them greater ease of movement when sitting, bending, or standing.
  4. #44
    I wear it with all buttons done up.
  5. #45
    25th March 08
    Louisville, Kentucky
    Quote Originally Posted by kiltimabar View Post
    I simply meant that a custom originating in "civilian" dress doesn't necessarily translate into a change in the separate tradition of the way highland attire is worn. .
    But how is a waistcoat worn with the kilt any different than a waistcoat worn with a suit? And I'm not ignorant of the fact that the cut is a bit different. Why wouldn't Edward VII have chosen to ease his waistcoat some in Scotland, where one may reasonably assume that his girth was no greater or no less than it was in the south?
    I guess what I am trying to say is that I see no difference --other than the cut of the garments-- between a tweed jacket and waistcoat worn with the kilt and a jacket and waistcoat worn with trousers.
  6. #46
    23rd August 08
    Unbuttoned, as I did when I wore three piece suits. Why? I was taught that is how a gentleman wears his vest/waistcoat.
  7. #47
    8th January 08
    The Bayou City - Houston, TX
    Boogers! Time's up.
  8. #48
    17th April 06
    I wear waistcoats with all buttons done up
  9. #49
    7th April 05
    Frederick, Maryland, USA
    Quote Originally Posted by Highlander31 View Post
    My big question would be why would it be worn that way. If you're supposed to leave it unbuttoned, why is the button even there in the first place?
    I can see undoing the button when you sit for comfort. Do you just leave it unbuttoned when standing for convenience? Did a notable person really leave it undone because of his girth, then everyone copied it?
  10. #50
    5th November 07
    Vailly-sur Sauldre, FRANCE
    Quote Originally Posted by davedove View Post
    The way I see it, it’s like when you wear a shirt or polo.
    You have people who will button them right up to the neck, and others who will leave the top button open.
    Why ?
    Personal style vs. conformity;
    Comfort vs. correctness;
    "Dad used to do it that way" vs. “My father wouldn’t have it otherwise”;
    Etc.
    Best,
    Robert
    Robert Amyot-MacKinnon
