10th January 10, 09:00 AM
I was going to give you sage advice, but it seems that everything has been covered. I would not pleat the front if you are going to wrap and buckle it, but that is a personal opinion.
Victoria
Just because you are paranoid doesn't mean they aren't out to get you.
10th January 10, 11:55 AM
Ali, I think that those pleats in the picture are not knife pleated, but might be heat set on a circle piece, so that the pleats widen from the top (hip) downwards. The hipline looks too slim to have had knife pleats sewn into it.
It's hard to tell for sure as the image is very small.
10th January 10, 01:06 PM
well, I have the actual picture which is a little bigger, and it looks to me like there is a top yoke that is fitted to the hip/waist area and then a pleated skirt that is attached to the bottom of the yoke. And then I assumed that the pleats were evenly spaced all the way down, what do you think Dixiecat (and others)?
Ali, I have posted in the Ladies of X-Marks group a few patterns for women's pleated skirts. I can scan the instructions for you, maybe that would help?
Julie
Thanks Julie, I think that would definitely help if you are able!
Why not, too much bulk?
10th January 10, 02:09 PM
I do like the look of the skirt just not sure if it needs an under apron though. Maybe just sew a join by the buckles and attach the buckles to each side of the skirt above the join. It's like a zipper but with flap and buckles.
Wallace Catanach, Kiltmaker
10th January 10, 05:36 PM
The yoke does a lot of the shaping - to reduce the time required to make the skirt, there isn't going to be a sewn fell - but it does look rather flared - and not a little odd - as though there are box pleats on the left hand side, knife pleats on the right.
Very strange.
You have to press the pleats - there is no alternative, if you don't do it before making up then you have to baste and press afterwards.
You still need to press as you work and smooth out wrinkles at the end but I find that pressing whilst the fabric is still flat, unpleated and unshaped saves time later.
10th January 10, 06:19 PM
Yes, the material I get from the mills is usually pretty flat and I can make the kilt without having to press the material. I always baste and then press to make sure the pleats are absolutely straight from the fell to the bottom of the kilt.
11th January 10, 09:16 AM
thanks Dixiecat, I'll look into that...
11th January 10, 12:02 PM
I have to say that the pic of the skirt you saw that you really liked, is **really** nice. I like it a lot. I think what you make is going to be a knockout.
11th January 10, 12:39 PM
Aww, thanks Alan! I hope I do it justice --wish me luck!
11th January 10, 08:01 PM
First, I have not made much on a sewing machine. I have made a tartan vest and didn't want to use the tartan material as my prototype. I made a muslin vest to check the fit and learn how to really do the vest before embarking on the tartan material. Worked out great too. Good luck.
By Nighthawk in forum General Celtic Music Talk
Last Post: 30th May 09, 03:42 PM
By Retro Red in forum Miscellaneous Forum
Last Post: 27th October 08, 12:12 AM
By Arlen in forum General Kilt Talk
Last Post: 20th April 08, 06:21 PM
Last Post: 29th January 08, 01:54 PM
By Kilted KT in forum General Kilt Talk
Last Post: 21st June 06, 09:00 AM
