View Poll Results: How do you use your belt loops on your kilt?
- Voters
- 190. You may not vote on this poll
For my belt and sporran strap
Only for my belt
Only for my sporran strap
I don't use 'em at all
My Feileadh Mor doesn't have any belt loops
27th September 10, 11:22 AM
#41
Belt loops? Why, for belts of course! 98% of my kilts have loops. My sporran straps sit quite happily just below the loops and therefore the belt and, if worn at the correct height, the sporran itself never slips - it can also be quickly moved to one side or the other without the buckle and keeper becoming caught up in the loops (which happens if the strap is worn through them!).
When I first began wearing the kilt, back in the early 1950s, I made enquiries of as many Highland Dress retailers as possible and studied photographs in their catalogues and elsewhere - there were no internet sites to consult! The advice I was given in this connection and the evidence I saw for myself was that the belt went through the loops and the sporran strap remained outside. This was also, as far as I could tell, how they were worn with uniforms on military parades.
No way would I ever feed a sporran strap through those loops!
Take care,
Ham.
27th September 10, 11:43 AM
#42
I tried it with nothing through the loops this weekend. That works just fine, too, though I'm not changing my vote.
"To the make of a piper go seven years of his own learning, and seven generations before. At the end of his seven years one born to it will stand at the start of knowledge, and leaning a fond ear to the drone he may have parley with old folks of old affairs." - Neil Munro
27th September 10, 03:18 PM
#43
Originally Posted by Mike_Oettle
Phil Corlis wrote: “If a kilt is shipped to me with loops, I take my stitch picker and remove them.”
That seems the sensible thing to do. I was wondering, though, what the lower loop would be for.
Mike
Sorry mate, lower strap on the right hip. Not really necessary, and in some cases it can distort the shape of the kilt apron.
Phil
27th September 10, 06:58 PM
#44
Both or belt although I have gotten away from a sporran belt and wear the newer front loops with chain to hang my sporran. It's more comfortable and easier to work with in casual situations. I made mine from an old sporran belt - clipped the chain short to fit, cut, folded and riveted the belts to make belt loops and I'm done.
28th September 10, 08:23 AM
#45
I sometimes use the loops (if they are there) for the belt, sometimes not, but in almost forty years of wearing the kilt, I've never put the sporran strap through the loops. Not right, not wrong, but just how I learned it when I bought my first kilt from an old Scottish gentleman.
28th September 10, 09:42 AM
#46
I have removed the belt loops altogether on some of my kilts that had them
28th September 10, 10:38 AM
#47
Phil
Although I'm no expert on kilt-making (nor did I stay at a Holiday Inn Express last night), I have found that the hip strap helps conform the kilt to the shape of your body. Without it, the kilt is only held up by - and suspended from - the top straps and kilt belt. Those top straps only apply a cinching force at the very top, relying mostly on friction to keep the kilt up, but they do nothing to keep the lower part of the fell snug to the hips and distributing the load of the wool around the back where all the weight of the pleats are. The hip strap helps keep the kilt in its proper place and draping properly, via this load distribution effect.
Does this make the hip strap "necessary"? Well, no. Of course not. But it does, in my opinion, make for a more comfortable and better-fitting kilt. I have kilts with the hip strap and without, and I find the hip strap to make a huge difference.
Of course, my disclaimer will be that a lot depends on the construction of the kilt, the shape of the wearer's body, and so on and so forth. I know some of the well-known kilt-makers have suggested that it's desirable to go without the hip strap, and I won't attempt to refute their experience or expertise. But for many folks, I think the hip strap makes for an overall better kilt.
If it's distorting the shape of the kilt apron, it may be a result of the kilt not being fitted properly, or the hip strap being installed too low.
28th September 10, 12:49 PM
#48
I only use 'em for my belt, and only with my longer kilts (higher rise). I've tried putting the sporran strap through them but find that it hangs too low (I don't have hips!).
Also, if they aren't supposed to be for your belt why are they so wide, the width of a kilt belt????
Reason: added info
The Kilt is my delight !
28th September 10, 02:07 PM
#49
According to Hammish I'm half right. After reading his post I moved my sporran strap outside the loops. He's right...moving the sporran to one side is less of a pain, and the strap isn't pulling on them.
I won't say I've changed my ways. I'm going to try it for a while and see how it works for me. I'll see how it works when I go on a fairly strenuous hike and really get moving.
Allen
28th September 10, 02:25 PM
#50
Never had belt loops on any kilt, completely unnecessary, never wear a separate belt, nor sporran straps or chains. A slim belt from which my sporran hangs is all that's required to stop the latter from falling off. The rest looks after itself.
By denmcdough in forum Kilt Advice
Last Post: 21st May 10, 05:25 AM
By Galb in forum Kilt Advice
Last Post: 6th May 08, 01:13 PM
By Standard in forum Kilt Advice
Last Post: 7th February 08, 10:28 AM
By SnakeEyes in forum How to Accessorize your Kilt
Last Post: 31st January 07, 09:25 PM
By Galant in forum Contemporary Kilt Wear
Last Post: 4th March 05, 02:34 PM
