Results 1 to 10 of 63
Thread: Buy a balmoral?
    6th September 12
    Coeymans Hollow, NY
    Buy a balmoral?
    If ya seem to be right between a L and XL, go larger? I want the cap to fit well, but not exactly sure how to measure. Actually it looks like I'm just at 7-1/2, which is at the lower end of XL, but just bought an irish wool cap that's L, and I like the snug fit. One of my fedoras (the only one labeled for size) is XL and fits great.
    An art & a science? It's one thing to go to a store and try hats on. For what I want to get, that just doesn't seem possible!
    Any suggestions? Thanks!
    Frank
    Ne Obliviscaris
    14th October 10
    Los Alamos, NM, USA
    Frank: For a balmoral, or any Scottish bonnet, I would eschew the L, XL, etc. designations. To my knowledge they are not standardized. Instead, use hat sizes, inches, or better yet, centimeters. Ask your wife to measure your head with a measuring tape (most have inches on one side and centimeters on the other). Have her place the tape on your head where you want the bottom of the bonnet to sit.
    A size 7-1/2 is 60 cm, or about 23.6 in. I suggest using cm, since most companies accept that unit of measure and it is more precise, since a cm is smaller than an inch. If you are indeed a 7-1/2, then your head will measure 60 cm. Assuming, as is likely, you fall somewhere between an even centimeter measure, then if you like a snug fit, round down. For a looser fit, round up. In any case good luck, because both measurement and manufacture are probably in the range of + or - 1/2 cm.
    John
    6th September 12
    Coeymans Hollow, NY
    Actually John, Gail got 60 cm, or 23-1/2. Again, I have hats that are different sizes, at least as far as the L, XL sizes go. It just seems to me to be an art, this measuring for a hat, especially when the only way I can get one is to order something very specific (i.e., 59 0r 60 cm). I'm looking here rigtht now: http://giftshop.scottishtartans.org/balmorals.html
    For hat sizing, I've been looking here: http://www.davidmorgan.com/hatsizing.html
    and here: http://www.villagehatshop.com/head_size.html
    50 bucks isn't a lot of dough, but I sure want to get it right. Maybe I should just go with the 60 and see what happens. Hmmmm.
    Thanks!
    Frank
    Ne Obliviscaris
    First of all, I like hats. Almost any type or style of hat. There was a time I was not without a hat outdoors. So I think I can shed a little light here on all the confusion.
    Just as we do with kilts. Always go with the measuring system of the person you will buy your hat from. Never use one sellers sizing info for a different seller.
    As with most things there are off-the-rack sizes and sizes for custom made. Off-the-rack sizes are usually pretty vague. A Large from one company may be a Medium from another. And their may be large differences within each listed size.
    If you question the sizing of a hat call the seller. Any seller worth your money should give you the exact sizing of their products.
    If you are looking for brand names there are two which stick out. "Robert Mackie" and "Glengarry Hats". Of the two I would choose Glengarry Hats for the following reasons.
    I have held balmorals from both companies side by side. The Glengarry was heavier overall and the wool was thicker and of a tighter weave than the Mackie.
    I found the Glengarry to take shape better. The Mackie shrank by 10% where the Glengarry shrank not at all.
    I liked the finish of the Glengarry better for its straighter stitching and the better liner. I found sizing more consistent with Glengarry. And I prefer the ribbon on the Glengarry.
    Finally, the Glengarry is about half the price of a Mackie.
  5. The Following 2 Users say 'Aye' to The Wizard of BC For This Useful Post:
  6. #5
    6th September 12
    Coeymans Hollow, NY
    This is the Glengarry one I like: http://www.glengarryhats.com/balmora...oralmaroon.php
    Thing is Steve, I'm asking family for kilt gifts and one son wants to buy me a hat. I'll get hold of glengarryhats.com (who I believe is the company you referenced?) and see what they say, then relay the info.
    Thank you VERY much!
    Frank
    Ne Obliviscaris
  7. The Following User Says 'Aye' to frank_a For This Useful Post:
  8. #6
    1st December 06
    Conyers, Georgia
    19 Post(s)
    At the risk of sounding like a nay-sayer, I must say Nay to Glengarry hats--well sort of Nay. (Disclaimer: this I based on experience from a few years back. Maybe it's different now, but there is that Negative Reinforcement thing, i.e., not being positively reinforced by avoiding the stimulus is quite strong!)
    I own one of their balmorals, a khaki that I really wanted. It fit well when it got in, no problem with the workmanship, etc. BUT . . . the amount of material in the bonnet is less than most bonnets, so it doesn't drape to the side like other bonnets. I have several bonnets, including a Mackie, and all of them have more material in the bonnet which allow the side to drape well over the sweat band. On the Glengarry model, it only just comes to the bottom of the sweat band and ends up looking like one of those modern military berets. (See a Legionaire wearing a Foreign Legion beret to get the idea.) It just doesn't look right, so I never wear it. I mentioned this once, and another prominent X-marker agreed. In fact, I spotted his bonnet as a Glengarry Hats version because of this.
    Also, I expect a small amount of shrinkage from a wool bonnet, so I would recommend going with a larger size if you fall in between sizes. And remember that working with cloth is always a bit sketchy; it's impossible to make two identical items exactly the same size. If a bit loose, you can sew a small strip of elastic inside to take up slack, better than trying to stretch one that's too small. I wear a 7 1/2 hat, so I purchase a 60 cm, and it works out fine.
    Yes, a Mackie costs more--substantially more--but it's a top quality bonnet that is proven as a fine garment. Ask around on the forum--Jock Scot,
    creagdhubh, or other experienced kilters. When you buy something like this, you want one that'll be with you for years. And a Mackie certainly will be.
    Jim Killman
  9. The Following User Says 'Aye' to thescot For This Useful Post:
  10. #7
    12th November 06
    Salem, Oregon
    Quote Originally Posted by frank_a View Post
    Frank
    I have a RED balmoral from Glengarryhats.com I got on ebay (http://www.ebay.ca/itm/NEW-Scarlet-R...item5d2ba1461c). I know, it's not a 60 cm one showing.... they don't appear to have that size available at the moment. I wear a 60 cm myself. Never noticed inadequate coverage over the right ear on mine: My brother and I at the Portland Highland Games this past July:
    When I'm ready for other colors, I'll be checking Glengarryhats.com again. I like the maroon one myself too!
    Had great service from Glengarryhats, quick delivery.
    Merry Christmas early Frank.
