Results 1 to 5 of 5
    14th April 22
    Dunstable, England
    Kilt + Pleat Calculator
    So I am crap at maths on paper - not ashamed to admit it - so I asked a kilt maker near me (Paul Henry) if he had any "sure fire" or "relatively accurate" ways to calculate pleats. He sent me a spreadsheet, which in fairness, was relatively accurate. I found however, it was slightly amiss for my own calculations as a much bigger man.
    I have however, now tweaked his spreadsheet, and I believe it is ready to upload here.
    It will work with both CM or Inches (and I have included a small calculator for the convertor)
    It will give you a calculation based on an odd number of pleats from 7 to 35.
    If you fill in the drop + rise it will fill in the persons fell (based on averages that it should be 1/3 the drop + rise).
    If you fill in the waist / hip size, it will fill in the pleat sizes to a 98% accuracy (I say 98%, as it was marginally off for mine, but to do the math on excel to 100% would be a nightmare, but its very very very close).
    Filling in the sett size also, gives you how much material you need for the number of pleats (example, if you were to do 7 pleats, for a 5 in sett, at the stripe, you need 35in of material, at the sett you need 42in of material).
    Filling in the waist size, it will give you how much material you need (Pleating measurement + 2 apron measurements = total length). I would suggest you can also make the addition for 20% for apron centring + spare material. Screenshot below, file attached.
    Pleat & Kilt Calculator Download Link
    23rd July 21
    Randers, Denmark
    Great work! Unfortunately, it doesn't work for me, here in Denmark.
    The link give me a error 404, in both Chrome and Firefox.
    Seems, out of the adress line, that a log in is needed...
    Best regards
    Tonni
    7th February 08
    Abbotsford, BC, Canada
    Error 404 , here on the Wet Coast ( or used to be) of Canada, also.
    26th November 04
    Dayton, Ohio
    The link is not correct. The URL posted is a very long string of random characters. If this is a Dropbox link it should be in the format:
    www.dropbox.com/<some random characters>/name_of_file.pdf?dl=0 (for a PDF file)
    14th April 22
    Dunstable, England
    Apologies, I don't know why this happened!
    New Download Link should definitely work!
