Results 1 to 10 of 11
    5th September 05
    Chicago
    sew fell up or down
    I just got one of the MacKenzie economies from Stillwater and like a dummy took the basting out (after assuring a good fit at the waist) and then realized (remembered) that SWK economies don't have the fell sewn. So I figger that I'll sew it myself just for the slightly better fit that it affords...
    ...so...if I pin the pleats should i sew down form the waist band or up from the point at which the fell begins? Also, if I try to do this by machine will that make any difference as to whether up or down...I've seen posts about a machine having a certain amount of slippage but I figger that the machine stitches will probably be tightr than what I can do by hand.
    Thanks...
    Best
    AA
    7th July 06
    Roswell, Georgia USA
    I believe you sew up, to ensure the bottom starts at the same place in the sett all along it. Becasue wool stretches, you could differentially pull it on different pleats and end up with it all williwaud. (that's a technical term among sporran makers)
    18th December 06
    Burlington, Ontario, Canada
    Quote Originally Posted by turpin View Post
    Poppycock! No such word!
    28th March 07
    Iowa
    I think it was a joke...
    9th June 06
    Midland, TX
    MacKenzie from SWK? WHen did those come available?
    10th March 07
    redding,CA
    If you use curved pins, other wise I'd baste it. Start from the bottom, and holding the material in front and behind the foot you are going to pull the material tight/snug as it travels under the presser foot, other wise you will get a little pucker in the top material when you get to the top, ( no matter how well you pin/baste). It's abit tricky at first so warm up on some scrap first. Good luck! And if all else fails int:
    29th January 06
    Asheville, NC
    If you are not careful you'll mess up the fit. I've tried this twice and had to rip out all the stitches until I wised up. Have someone pin the pleats down at the bottom of the fell while you are wearing said kilt. Otherwise it will never hang right. Since there is so little taper in it already if you just pin it while it's lying on the tabe you'll end up with a stove pipe, and the aprons will pull mightily when you put it on.
    15th April 07
    State College, PA
    OK, as Barb says: sew from the fell up, stretch the material to taper the pleat from the fell pleat width to the waist pleat width. You do know what the hip and waist measurement you are tayloring the kilt to? It may not be as easy as just sewing the pleats.
    Wallace Catanach, Kiltmaker
    13th December 06
    Bartlett, Tenn
    Wink Southern Tawk!
    Quote Originally Posted by ccga3359 View Post
    It's a SOUTHERN word! We have all kinda words you Canadians AIN'T GOT! Ain't you never hearda Jeff Foxworthy? There are several Southern dictionaries and books on "how to speak Southern." If the English language can be mangled, I garontee {a Louisiana word} we goin' ta do it!
    29th April 07
    Columbia, SC USA
    etymology of williwaud?
    Mmm, actually I think it's a participle, describing one of two conditions
    (a) sewing a seam in a watercraft which is struck by a williwaw;
    (b) attempting to sew a pleat after one to many gude-willie-waughts!
    Quote Originally Posted by Beuth Sim View Post
    It's a SOUTHERN word! ... If the English language can be mangled, I garontee {a Louisiana word} we goin' ta do it!
    I agree about the mangling part, but be cautious with the 'Cadien---our friends might lay some Quebecois on us, resulting in mutual incomprehension.
  1. Machine sewn pleats - fell to waist or...
    By pdcorlis in forum DIY Showroom
    Last Post: 27th January 07, 08:42 PM
  2. Honey, the dog fell in the moat again!
    By Shay in forum Miscellaneous Forum
    Last Post: 27th February 06, 03:20 PM
  3. the old fell-in-stillwaters question
    Last Post: 23rd November 05, 12:19 PM
  4. Sewing a fell on a Stillwater Standard?
    By Bil in forum Kilt Advice
    Last Post: 17th October 05, 09:27 AM
