Results 1 to 10 of 12
Thread: Color bleeding
    19th September 09
    New England, USA
    Unhappy Color bleeding
    So I wore the kilt out today to pick up some odds and ends and wile I was out I was a little warm. I am a gentleman of substance so I did sweat a little. Upon taking the kilt off I found my shirt stained red from the liner in the kilt. Is there a way to prevent this? Is this normal? And should this be fixed?
    Colossians 4:6
    2nd May 10
    Roseville, California
    No.
    I have not heard of that Cowher. I would be concerned about the color bleeding back into the kilt too. If it is worth your time, and expense, I would definitely have the lining changed to a colorfast material. It wouldn't take too many shirt replacements to justify the repair cost. That is assuming of course that it is a budget kilt that would not likely have a kiltmaker standing behind it.
    Best of luck!
    3rd March 10
    43*N 88*W
    Quote Originally Posted by MacMillan's son View Post
    Best of luck!
    This ***
    A good shirt will probably cost the same amount as replacing the liner w/ something more stable and colour-fast.
    Don't waste good shirts.
    ith:
    Chirs is offline Oops, it seems this member needs to update their email address
    11th March 11
    Barrie, Ontario
    I've never heard of such a thing and I'd be more than concerned. Is this the first time you've worn this kilt? First time you've been so warm in it? I'd be talking to the maker...
    22nd January 07
    Morganton, North Carolina
    Quote Originally Posted by Cowher View Post
    What sort of kilt is this?
    19th September 09
    New England, USA
    Quote Originally Posted by Chirs View Post
    This is not the first time I have worn it. But it is the first time I have warn it in warm weather.
    I emailed the kilt maker about a hour ago. He was great to deal with when I commissioned the kilt so I am sure he will take care of this quickly.
    Colossians 4:6
    10th October 08
    Just a comment: I've noticed that red dyes tend to bleed (no pun intended) more often than other colors, even with items that are supposedly 'colorfast'. So much so that I have a couple of red(-ish) sweaters (jumpers) and some red bath towels that I have to wash separately or the red dye will stain some of my other clothes. Even after several washings there is a trace that will 'bleed out'. (Consequently, I don't wear/use those items all that much.) I'm equally cautious when wearing those clothing items to not get them wet or perspire too much in them lest I stain what I'm wearing underneath.
    It may have something to do with the particular dye used, or the method for dyeing/fixing the dye, or the material involved. I dunno - just a guess.
    The two kilts I wear have a black liner (a lightweight - maybe poly-cotton - material over a rougher woven fabric) and a blue liner (what appears to be a cotton twill material over a heavy linen). (I'm guessing at the material - I'm not a clothier.)
    John
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    One reason why I use a natural un-dyed lining material (in this case silk), so I'll never have to worry about getting a phone call from one of my clients about dye bleeding from the liner onto his shirt (or worse yet, the kilt!).
    23rd September 09
    Vassalboro, Maine
    Silk?
    Ooh, I can feel the raw silk now.......
    but how does that do with heavy sweat?
    28th May 08
    Trumansburg, NY
    Quote Originally Posted by Tartan Tess View Post
    Silk?
    Well I can say that I have never had a problem with the liner material that Matt uses. Great stuff really. I lay mine out overnight to let them air out after wearing them and they dry right out.
  1. Color choices
    By JamieKerr in forum Kilt Advice
    Last Post: 20th October 09, 01:54 PM
  2. Length and color of tie.
    By chacbalam in forum How to Accessorize your Kilt
    Last Post: 30th January 06, 04:10 PM
  3. Color Choices
    By davedove in forum Kilt Advice
    Last Post: 12th January 06, 06:39 PM
  4. What color should I get?
    By Big Paul in forum How to Accessorize your Kilt
    Last Post: 13th January 05, 06:11 AM
  5. WW1 in color
    By Buddha in forum Kilts in the Media
    Last Post: 20th December 04, 06:05 AM
