Results 1 to 4 of 4
    14th July 09
    Cuyahoga Falls, Ohio
    Cobbled together Kilt Pin
    Found a pin at a garage sale for under a buck and decided to replace the charms on with more to my liking.
    Simple project, I'll admit, but I figure there isn't one quite like this out there anywhere else.
    As found:
    My charm -- an old bagpipe pin with the studs removed:
    Copper wire around the middle tenor drone, coil spring above that. (And a few inches of dental floss, just in case the metal fatigues.)
    On display:
  2. The Following 2 Users say 'Aye' to jeremy j starche For This Useful Post:
    16th June 13
    Post Falls, ID
    That is just cool!
  4. The Following User Says 'Aye' to James McFetters For This Useful Post:
  5. #3
    13th May 13
    Idaho
    That is a great idea
    Member of Clan Hunter USA,
    Maternal - Hunter, Paternal - Scott (borderlands)
    Newly certified Minister.
    If you cannot fix it, mess it up so bad that no one else can either.
  6. #4
    Quite clever - good re-use!
