Results 1 to 9 of 9
Thread: Steam Blanket
    26th November 04
    Dayton, Ohio
    Steam Blanket
    When I attended Kilt Kamp this past summer we setup a steam station on one of the large tables in the classroom. We had to protect the wooden table top from damage from the steam. A steam mat was made out of ironing board material, thermal batting, and a vapor barrier. When I got back home I thought it would be a good idea to have something like this. I have a large drafting table that I use with a large cutting mat which could serve this purpose when I don’t have the cutting mat on it. Rather than having to assemble separate pieces of material when I wanted to use the steam mat I wanted one more permanent. I found ironing board material at JoAnn Fabric along with the thermal batting. The batting is called Insul-Bright and is sold by the yard. It is made from a poly batting with a reflective metalized film. The metalized film serves as a vapor barrier but in class we found it was not sufficient. Vapor was getting down to the table. We added a thin layer of plastic which I think was nothing more than garbage bag plastic. Rather than use plastic sheeting I found a Space Emergency Blanket still in the original packing. These are made from a metalized Mylar material. The MSDS sheet indicates the material is Polyethylene Terephthalate that can take 235 degrees F before it breaks down. That should be sufficient since the plastic we used did not melt. To protect the Mylar vapor barrier I added a bottom layer of bottom weight poly/cotton material. Sewed it all together with edge binding. Sewing this was a little bit of a challenge as the Mylar is very slippery and the top batting wanted to slide around under the pressure foot of the machine. I ended up hand basting all the way around the edge of the assembled layers to help hold it all together. Once I sewed down the top of the double fold binding I took a rotary cutter and trimmed the material flush with the edge of the binding. Wrapped the banding around the layers of material and “stitched in the ditch” to connect it all together.
    My only concern was how well the Space Blanket will hold up over time. I am concerned about it ripping. I will just have to monitor for any vapor leaks as time goes on.
    This is what the final blanket looked like on top of the table:
    I ran a temperature and vapor test to make sure it worked as intended. I placed a couple of paper towels under the blanket and a thermometer. After repeated hits of 10 seconds of full steam the paper towels were dry. The thermometer hit 140 degrees at one point. As long as I don’t place the steam blanket on top of my cutting mat it should be fine. I think the table top can take the temperature.
    This is how the layers of the blanket were put together:
    So now I need to make another kilt to try it out.
    Mike
  2. The Following User Says 'Aye' to Mike in Dayton For This Useful Post:
    7th July 09
    Melbourne,Victoria Australia
    Thanks for that informative photo essay Mike. Looks to be a top bit a kit that would not go astray in any kilties house. Cheers to you and the steaming mat
    14th July 12
    St. Paul, Minnesota
    Great post. It looks like it should perform its task beautifully. Anything beats fighting an 8-yard kilt on an ironing board.
  5. #4
    I have Mylar patterns which are well into their teens now - so you might be safe for a few years at least.
    I have a sturdier version of the space blanket which has a plastic mesh reinforcement and a layer of plastic - that is over 40 years old so don't know what temperature it can withstand without doing a bit of destructive testing, which I am loathe to do on such a well travelled and useful item, but it would be an alternative to the simple version.
    An emergency alternative for a steam barrier is opened out cardboard boxes, the ones with two layers of corrugations are the most insulating. If you need to join them use gaffer tape on the underside, but then put a layer of paper between it and the table, just in case.
  6. #5
    18th August 13
    Great information -- thanks for posting!
    Allen Sinclair, FSA Scot
    Eastern Region Vice President
    North Carolina Commissioner
  7. #6
    8th May 10
    Kent, OH
    Beautiful work, Mike! Glad you've been keeping yourself busy since Kilt Kamp. All those layers and all that masking tape to hold it down seemed a bit much to me, but didn't seem to phase Steve. How do you keep it from shifting on your table? Masking tape? LOL! Probably not, huh? Great use for the table too, I might add. I kind of figured you'd come up with an interesting use for it.
    Beannachd!,
    Jon
    Only 9 notes. How hard could it be?
  8. #7
    7th February 11
    London, Canada
    Interesting project!
  9. #8
    26th November 04
    Dayton, Ohio
    Quote Originally Posted by MacIllfhilidh View Post
    Beannachd!,
    Jon
    For now I am using a couple of clamps that were not on the table when the picture was taken. I also use the table for my large cutting mat which is held in place with the same clamps.
  10. The Following User Says 'Aye' to Mike in Dayton For This Useful Post:
  11. #9
    7th February 08
    Abbotsford, BC, Canada
    Quote Originally Posted by Mike in Dayton View Post
    Mike
    ah yes, ..making excuses, so you can get your fix .. sure signs of Kiltmaking addiction
  12. The Following 2 Users say 'Aye' to jhockin For This Useful Post:
