It is possible to manipulate a kilt, particularly one made without the usual reinforcements and reduce its size and where it sits.
I have taken a couple of inches out of a waistline by tacking a length of tape around at the correct level on the outside of the kilt and pressing to gently persuade the fabric into the correct measurements.
I then took a length of shaped waist tape and sewed it into the inside upside down to the usual way it is used, with the wider edge uppermost and the narrow edge at the waistline.
Over that I put a tape at the waist which was wide enough to support the straps and buckles and take the strain of wearing and then put in a lining.
This corrected a kilt made with the narrowest measurement at the very top, which sagged no matter how much the straps were tightened. It also took the strain of the vertical sewing which was already showing the effects of the strain being put on the pleats.
Most competent dressmakers should be able to do a similar correction if you are unlucky enough to buy a kilt without the correct shaping, but it needs to also lack the reinforcement unless a dismantling can be achieved without doing damage. Sometimes glue is involved, which is rather bad news.
Anne the Pleater
