Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    13th March 05
    TT, the original poster asked for suggestions in February 2005. I hope he's got it figured out by now!
    17th July 08
    Fayetteville, NC
    Quote Originally Posted by Jimmy Carbomb View Post
    I've actually seen guys use weights on the end so that it will drape over the shoulder with minimal movement. Weight will also need to be sewn-in on the back side to evenly disperse the "pull" over the shoulder. Put the brooch over the weights on the front, and it still looks like it's attached.
    The best weight to use is the "lead tape" that guys use on golf clubs. Many sporting goods and department stores stock this stuff in the Golf area. You should be able to stitch-in a couple "tack" spots to hold it firmly.
    This would need to be inside and out of the wind. If you have the pocket, the weights will help there too.
    What would be even easier to use are drapery weights, lead already encased in fabric and sold by the yard. Any good fabric/drapery place should have it. It would be a simple matter to stitch it to the plaid, then when the wife gets cold (seems to be their nature at formal do's) There would be no problem.
    highlander_Daz's Avatar
    9th February 05
    Inverness Scotland
    easy answer was . dont wear it I have a pipers Plaid now much better
    8th January 08
    The Bayou City - Houston, TX
    Take a small safety pin and either: pin the plaid to the jacket; or, pin the plaid to the epaulet.
    14th January 08
    San Antonio, TX
    I dont pin the plaid to the jacket at all. My plaid has enough fabric bunched and pleated far enough back from the corner to perfectly fit beneath my epaulet without much looseness, then is held in place simply by the wieght of the plaid brooch pulling down in front fairly balancing the weight of the fabric aft of the epaulet. I think it ruins the fabric to pin through either the jacket lapel or front. If the brooch is not enough weight to balance then perhaps sewing osme curtain wieghts into the front of the pleats might be an option, but I have never needed to.
    27th August 08
    Portland Dorset UK
    What about those magnets you get at tool stores they are about1.5" diameter and 0.25" thick and they have a hole in the center. Sew one to the plaid and just put the other tied to a small amount off thread behind the lapel.
    5th August 09
    Toronto, Canada
    safety pinning the plaid to the jacket works.
  8. #18
    5th August 09
    Toronto, Canada
    Quote Originally Posted by Macman View Post
    I just noticed this comment.
    If he hasnt figured it out yet......................my thoughts are with him.
  9. #19
    13th March 05
    Quote Originally Posted by Andrew M. Stewart View Post
    He has; see post #13.
  10. #20
    5th August 09
    Toronto, Canada
    Well thats good...great! Glad to hear it...hate to think that he ... well you know.
