29th November 06, 05:54 PM
Sorry I am late coming to this thread, but my advice would be to pleat to the stripe, and here is why:
This tartan is a military tartan. Traditionally, military kilts were pleated to stripe. Not that a military tartan cannot be pleated to sett if it is a civilian kilt (not part of the uniform), but pleating to stripe would be a nod towards the tartan's military heritage.
Specifically, I'd pleat to the light blue/yellow stripes on the green, both because that is the obvious stripe, and also becuase tartans based on the Black Watch sett (which this one is) are typically pleated to whatever stripe is on the green portion of the sett, enabling you to work more easily with the large sett created by such tartans (as has already been discussed).
And lastly, I just think it would look sharp pleated to the line.
Of course, it is your kilt, and the best advice is to get it pleated however you want!
M
29th November 06, 07:27 PM
Of course, it is your kilt, and the best advice is to get it pleated however you want!M
I'm with Matt and it is the millitary style.
MrBill
Listen to kpcw.org
Every other Saturday 1-4 PM
29th November 06, 10:25 PM
Sorry I am late coming to this thread...
No, no. Don't appogoze to me, I'm honored to have your opinion regardless of when I get it. Thank you.
29th November 06, 08:21 PM
I think this would look good pleated to either the sett or the stripe.
My personal preference would be to pleat it to the stripe, but it can give a loot that can be surprising based on what colors surround the stripe. Looking at this, I think you will have a very yellow look to the back of your kilt but I would be ok with that. I would just do some folding and pinning and see if you're happy with it.
I think doing it to the stripe is easier in concept because the lines are right there, you don't have to figure much out. Just line everything up and there you go...but Barb is right..execution is everything. When you do it to the stripe, being a little off shows up right away.
Whether you use each sett or every other sett to do your pleats depends on how far apart the setts are and how deep the pleats would be on each or every other sett. If they are too close you will end up with shallow pleats. I prefer ending up with about a 3 inch depth. Again, try it by folding and pinning and see what you get.
It's a beutiful tartan. Good luck with it
29th November 06, 10:01 PM
Wow, just when I think that the thread had died from disinterest ...
Thanks to All.
 Originally Posted by SingleBarrelBourbon
The Polaris tartan is next on my list. ...
Yeah, me too. Tomorrow in Property tax day here. Once again the city is helping itself to my wallet. Sigh, no new kilt this month...
 Originally Posted by Monkey@Arms
how much is this kilt going to set you back?
Prices are on her web site but I think the final damage to my wallet after the smoke clears will be about $560.
29th November 06, 11:35 AM
 Originally Posted by wsk
Good day Gents,
Since I rediscovered its existence about a year ago, I've been wanting a kilt made from the Polaris Military tartan.
Why I didn't find Alexis Malcolm during my original search remains a mystery. Now I have in my hot little hand an actual swatch of the Polaris so all that needs done is to send in my measurements and a pocket full o' bucks and to choose whether to pleat to the sett or to the stripe. This is where you all come in.
WSK,
I too would love to get a Polaris kilt someday. I understand that since the tartan is no longer in general manufacture, one has to pay a premium for a special run of the material. If I may ask, how much is this kilt going to set you back?
Best regards,
Jake
29th November 06, 05:26 PM
...pleated to the stripe. The reason...it's easier.
To be honest, I think pleating to the stripe is actually harder. Yes, it's easier to lay out the kilt and figure out where to put the pleats, but it is harder to make the pleats look good. The main stripe has to be absolutely centered from bottom to top, and each pleat has to be perfectly tapered from bottom to top. Unless you've made a lot of kilts or have a _lot_ of patience, it's hard to do this perfectly. I still prefer pleating the the sett and can make a kilt faster if it's pleated to the sett, and I've made zillions of kilts.
On the question of why the tartan is not square: it ought to be because tartan is what weavers call a "45" weave - the twill line should be at exactly a 45 degree angle. Some handweavers adjust the threat count to make squares absolutely square when the tension is off the warp. In commercially-woven tartan, squares are never square, in my experience, and the warp-parallel dimension of the sett is longer than the weft-parallel dimension. So, if you're figuring out the sett, measure parallel to the warp (the long dimension of the tartan).
And a sett is the full repeat of the tartan, where you can start over again and get exactly the same pattern of stripes. A tartan can repeat A-B-A-B (like the Wallace or Rob Roy) or A-B-A-C-A-B-A-C like the Black Watch or even A-B-C-D-A-B-C-D (an asymmetric tartan like the Ancient Campbell of Argyll). The full sett for an A-B-A-B tartan is A-B; for the Black Watch, it would be A-B-A-C. You could pleat to the stripe every half sett if you pleated to the "A" block or to every full sett if you pleated to the B or C blocks. That's what chasem is talking about with the Forbes.
Barb
29th November 06, 10:12 PM
 Originally Posted by Barb T.
On the question of why the tartan is not square...
Tidbits for the second edition ...
So, answer me this: If I have a swatch in my hand and pull gently along the warp or weft (I don't know which because it's only a swatch), can I deduce by how the fabric stretches which is warp and which is weft?
The Polaris swatch I have is more stretchy in one direction than it is in the other.
And a sett is the full repeat of the tartan, where you can start over again and get exactly the same pattern of stripes. ...
Just read that in your book. All straight now, thanks.
30th November 06, 06:38 AM
Yes - woven fabric is very slightly stretchy parallel to the weft and less stretchy parallel to the warp (the long dimension of the yardage). That's because the warp is under tension when the fabric is woven and the weft is not. The weft climbs over and under the warp threads, which are in tension, and, once the fabric is woven, it's possible to pull those little up and down excursions out straight, giving the weft direction a little stretch. That's why pattern pieces for garments have the "straight grain" of the fabric along the length. You don't care if your pants stretch a little around, but you don't want them bagging and sagging along the length.
Barb
30th November 06, 07:54 AM
Guys, why don't all of y'all who want a Polaris tartan kilt get together and see if you could get a single custom run instead of 3-6 seperate ones. It would be cheaper that way, especially of you get over 10 yards (double width is then possible, and still cheaper/yard than 8-9 yards single width).
As for seting the kilt, I'd say to stripe. If the stripe-to-stripe measurement ends us at 4.5 inches or so, set it to the ACTUAL full repeat, which (like all Black Watch based ones that keep the alternating one double and twin double lines on the blue/navy) is actually 2 sets of yellow/light blue for a 9 inch repeat. This is how I am setting my PV Gordon box pleat (boxes centered to every other yellow, so centered on yellow on box AND at opening center section).
Additionally, an otherwise dark tartan with a single stripe/set of stripes in bright, I would ALWAYS set to stripe in a knife pleated kilt. I like the look that way. In a complex tartan with multiple stripes, like Caledonia 155, I would either do a box pleat or a pleat to sett, as such complements the tartan MUCH better.
(Just in case one was wondering, a box pleat is generally set to a broad stripe, 2-3 inches wide. Setting a box to set is next to impossible for most tartans.)
Reason: Clarifying Gordon info.
By davecolorado72 in forum Kilt Advice
Last Post: 25th October 06, 07:18 PM
Last Post: 19th July 06, 01:39 PM
By MacWage in forum The Tartan Place
Last Post: 4th July 06, 08:35 AM
By auld argonian in forum Professional Kiltmakers Hints and Tips
Last Post: 26th October 05, 10:12 AM
Last Post: 27th May 05, 03:07 PM
