Results 11 to 20 of 64
    30th December 06
    My thanks to way2fractious for his comments. He's quite right, it's not just the kilts. Trying to reproduce the military box pleat has been very time consuming, extremely frustrating and now, very satisfying. It is also quite likely that I will make almost all of my future kilts in this style as it provides an indescribable, but satisfying extra something to kilt wearing.
    I wrote up this account as a journal during construction, which is not yet complete. So, you may notice bits that have been covered in other posts.
    How I did it. (There are other ways to do this, but this is what worked for me.)
    Measure & mark the cloth as normal for pleated to stripe knife pleats. Grab the outside edge of each pleat at the hip, fold the extension (the box bit) back on itself and pin it from top to bottom. (Make sure that the dominant stripe is centred in the folded bit.) Now, adjust the hip to waist portion of the pleat extension and taper it to the waist, keeping the dominant stripe centred and make sure there is no taper in the rise, then baste both edges, about 1/8” from the edge, beginning with the one furthest from you. (Right side up, top to your right. [Top to your left to baste the other edges.]) Baste all of the extensions before beginning to sew.
    View from bottom. Pleats are stitched at X, edge to edge.
    All pleat extensions basted. I removed the fell basting after sewing them down. The rest of it will come out after pressing & finishing.
    When you have basted all of the box extensions, sew the edge closest to you of the first box extension to ONLY the first layer underneath it. (Right side up, top to the left.) (NB the visible edge of the deep pleat at the right of the apron is NOT folded over. [Must be a part of that elusive Specification!]) Then sew each pleat extension with a catch stitch* to its’ neighbour. (I suggest that you practice first with some scrap fabric as it takes time to figure out how things are going to behave and you don’t want to damage good fabric by repeatedly ripping out stitches. [Please don’t look too closely at my first pleat!]) Right edge to the next left edge. (When viewed with the top at the top,)
    (* I assume that this is the stitch to use here as it is the only one that I found would do the job. I welcome any input from the experts on this point.)
    Sorry, my camera seems to have a problem with macro auto-focus.
    Open the seam a little to give yourself room to work. Use some backstitch, this way, that way, as necessary, to keep the horizontal stripes lined up.) from hip to top and MAKE SURE THAT YOU ONLY CATCH ONE LAYER! Repeat. Repeat. Repeat. Once you have joined the last pleat to the under-apron, proceed as for a pleated to stripe kilt.* The start and finish of the project are no different to a normal knife pleat kilt. It’s just the way the pleats are formed and stitched.
    *I have been re-reading some older threads and I found in one,
    (http://www.xmarksthescot.com/forum/s...ad.php?t=16994),
    that way2fractious had had a go at the same thing and had noticed that there was just one stitched layer at the back. Since I did, partially, reverse-engineer a military kilt, I can confirm that this is so. What they did with mine was to taper the cuts over a longer length, but that the remaining bits are only about ˝” wide at the bottom of the canvas and probably the rest of the way to the top. With 18oz. material, strength may not be an issue, but with the lighter materials it might be better to leave larger pieces. Also, the canvas in mine is not as tall as Barb recommends, so following her suggestions here on how to taper the cut and size of the canvas would add strength.
    Close-up of pleat cuts in my QOH kilt. After the initial sharp cut the taper is gradual down to about ˝” at the bottom of the canvas. Also, the steeking is doubled up.
    An odd thing, but it makes life easier should you later find that one of the horizontal stripes is not aligned properly, (Mea culpa!) is that you only have to rip out one row of stitches to correct the problem, unlike a knife pleat job where you have to rip all the way back to the offending pleat.
    Look at the left edges of pleats 5 & 6. Pic on the right is after I redid them. (The 2 safety pins, (Quilter’s pins, which are curved and much easier to use,) are keeping the buttonhole closed. The pins to the left are keeping the deep pleat aligned at the back.)
    The reinforcement strip, canvas & steeking are absolutely necessary as the pleats are NOT sewn through 4 layers. (If they were, you could not cut away enough excess fabric & the top of the kilt would be too bulky. You have 2 extra layers here! But, when you have finished, there is no difference to a knife pleat kilt.)
    Pleats all stitched. (The horizontals are straight. It needs cutting the excess and pressing to show that. The pin marks the centre-back.)
    The illustration below shows the view of both types of pleating when viewed from the top by holding the kilt right side to the top and letting the pleats swing free. The stitches on the knife pleat version go through 4 layers, but the military box version only stitches one layer.
    When I started to baste the pleats, I found that the bottom of the folded bit was curling up so, I removed the basting from the left edge and replaced it with a baste through all 3 layers along the edge. (As done by way2fractious.) This will take time, but it will be a lot easier next time.
    Can not wait to see it John, I must say that I was very impressed with the kilt you were wearing when we met at Fionn McCools.
    Robert MacDonald of "West Coast Kilts" is a retired military kiltmaker that has quite a bit of experience with the Military Box Pleat.
    He is a member here and goes by the nic of kiltykiltycauldbum.
    Perhaps you and w2f might collaborate on a manual? *hint, hint*
    think of it as an addendum to the Art of Kiltmaking. 10-13 pages plus a dozen photographs should do it.
    5th January 06
    Manteca, California
    Why am I not surprised that Alan H suggests someone else write another manual?
    JohnH, I read through your info above - and found myself tripping down memory lane. The pics of pleats basted into place with two vertical basting lines, and several other lines too, made my fingers itch. Those pics match some that I posted a long while back.
    The good news is: What you and I posted were still learning exercises. When I covered some of these steps with Elsie, and showed her my practice pieces, she steered me back into steps that more closely align with those of the traditional knife-pleat. The practice pieces allowed you and me to explore and confirm the mechanics, but the actual process is really much easier.
    Back to Alan's nudging, I made one aborted attempt to re-write certain paragraphs on certain pages of The Art of Kiltmaking. I abandoned it because in truth it would have been an act of plagiarism against Barb T, whom I had not consulted regarding such a thing. Perhaps it still could be done, with her permission and/or involvement. I will be seeing her in a couple weeks in Victoria, BC at the 2007 Kilt Kamp. (Another item for that weekend's agenda. )
    30th December 06
    In the regiments, a band of elastic is tacked in the inside loosely across the pleats, probably to help keep the intricate pleats from unfolding too much and not refolding correctly. (w2f)
    Just like this:
    Elastic is sewn to alternate pleats. It is 5 1/2" up from the bottom. My knife pleat ex Black Watch does not have this, so it would appear to only be used on the box pleat kilts. My very first kilt was ex-Seaforth and it had the elastic.
    The good news is: What you and I posted were still learning exercises. (w2f)
    I hear you loud and clear. My Douglas currently has bastings running every which-way! But, it's the best way to learn. This leads me to have some sympathy for Alan H's request for a manual, as I do believe that this technique should not be allowd to die out. Speaking of which, The new Royal Regiment of Scotland’s kilts will be made in Scotland with fabric woven by Robert Noble, although it will be 16 oz. and they will be machine-stitched (Hmmm....will this quest never end?) box pleats, using a version of the Argyle tartan with a lightened green. (Basically, Black Watch. Does this make it Pattern 1B?)
    [The 64 hand sewn prototypes that were made by Argyle Bagpipes were recently offered for sale on eBay.co.uk. I did not buy one because they are current issue, but, it was very tempting. {It’s an honour thing. I do wear my Naval dress sword belt (minus the frog) with my kilts even though it is still current issue, but I did serve in the RN, as did both of my parents. I never did and never will serve in the RRS.}] The expired auction can be seen at:
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...3216&rd=1&rd=1
    Note these kilts may be relisted later as none appear to have been sold.
    (w2f)
    I was originally going to be there, but my work has an annoying habit of interfering with my leisure time and I had to cancel.
    I read through all the posts three times before the penny dropped as to what this is.
    It is a box pleat, not the three layer 'simple' nor the five layers of the same size version - it is, as I count them, a variant of the five layer with three layers the same size and the inner two layers extended to cover two pleats.
    Sort of a box pleat and knife pleat combined.
    I can 'see' it now - but the thing would be to make one.
    Just to be sure that I have it clear, for the standard male pattern, the longer back fold - that is the same orientation as the single pleat of a knife pleated kilt, and would point towards the back on the left and the front on the right?
    I wonder if I can adapt it to a Kinguisse style and not go mad in the process? No need to answer that, I think I lost the plot some time ago.
    I do have some not really a tartan fabric, which has a nice stripe in it though - I must have a go just to see if I can do it.
    Reducing in size would require the inner workings to be removed and the individual pleats in the fell made narrower - I think I might make this kilt several inches too small for me at the moment, by the time I finish it it will probably fit.
    Ah the joy of kilt making - just when you think you have really got a handle on it someone adds a whole extra dimension.
    30th December 06
    It's probably closer to a knife. If you lay out a kilt for knife pleats and then fold the reveal part of the knife back on itself, you end up with the military box pleat. Of course, the stitching is completely different.
    Yes, the back part of the pleat is standard knife and the front (visible) part points the other way.
    If that doesn't drive you mad, consider (like me!) the possibility of doing this to the sett!
    But without the continual challenges, life would be boring.
    21st April 07
    Arizona
    I have to confess that, even with the diagram, I still don't understand what makes a military box pleat different from what Matt makes. I guess I'll have to buy one and see....
    5th January 06
    Manteca, California
    Here are some pics comparing box pleats to military box pleats. Hope these help.
    Here are the box pleats you have seen - basted up at about 2 1/2 inces wide. See how few there are to cover my skinny backside. This is a 4-yard kilt.
    The left side of this pic shows the depth (about 2 inches) and reveals (about 1 inch) of a military box pleat kilt. I needed all 8 yards of tartan for this kilt and about 21-22 of these much narrower pleats.
    The following was posted by Panache - pics at a kilt night where Alan H was wearing his California tartan box pleat kilt (4th pic) and I was wearing my Weathered MacLaren military box pleat kilt (5th pic). The differences are quite distinct, but each is a kilt, each has its place, and everyone has preferences.
    http://www.xmarksthescot.com/forum/s...48&postcount=1
    Now, if you ask again...
    I'll drive down to Arizona with my whole kollection (threaten, threaten)
    BTW - did you mean to buy a box pleat from Matt or an MBP from me?
    w2f
  1. Replies: 23
  2. Kilt pins from military awards.
    By Richland in forum How to Accessorize your Kilt
    Last Post: 17th May 06, 08:51 PM
  3. Military box pleat trial
    By way2fractious in forum Professional Kiltmakers Hints and Tips
    Last Post: 6th May 06, 03:49 PM
  4. how to wear military kilt
    By mcnice in forum Kilt Advice
    Last Post: 16th October 04, 02:30 AM
  5. Military surplus kilt
    By Raphael in forum Contemporary Kilt Wear
    Last Post: 15th May 04, 05:55 PM
