24th July 07, 09:35 AM
Thanks for the welcoming words!
Yes, magnets can cause damage to credit cards and hotel keys! But you really have to work at it. As to the possible damage to cell phones, I don't believe that one. If you opened up your phone and rubbed the magnet repeatedly around on the circut board, maybe.
As to where in the hard drive the magnet is, my advice is to take apart all that you can. Pry, twist, remove screws, etc, and then take a metal object and hold it close to the parts. Believe me, you'll find it.
Hope this helps.
24th July 07, 09:55 AM
I have a couple of computer lobotomies at home. I will have to try this!!
[B]Paul Murray[/B]
24th July 07, 10:11 AM
24th July 07, 07:56 PM
When using magnets you need a piece of ferrous metal for the magnet to stick to, like a washer or something. When the magnet is stuck to the washer most of the magnetic field will be going through the washer so it will be almost no risk to credit cards unlike a loose magnet.
Peter
24th July 07, 08:17 PM
I'm glad to see the warnings about credit cards and hotel keys. I've messed up hotel keys with the magnet from a name badge a couple times at conferences.
The danger is real. I'd never use magnets in a sporran.
Virtus Ad Aethera Tendit
25th July 07, 03:31 AM
 Originally Posted by mddock58
...and these are the magnets removed, but still attached to their mountings.
Thanks mddock58, that's exactly the type of hint I was hoping for. I've disembowelled a number of drivers over the years, (I've got a stack of old platters in my office at work) but I've never gone after the magnets before.
Best regards
25th July 07, 05:43 AM
Magnetic "information" CAN be changed by magnetic fields realigning the "data" on whatever it is on. the biggest danger to credit cards and such are the "Security" demagnitizers at stores ( so you don't walk off with a CD or DVD) which have a strong rapidly changing field.
Generally a magnet will not cause a problem with most items, but a magnet in a pocket or sporran freely moving about may cause data loss. It is not a simple "this will, and that won't". Caution in the size and strength of a magnet should always be considered.
Using them to keep a kilt pin on should not cause any worry, unless there is a metal plate in your leg!
Mark Dockendorf
Left on the Right Coast
By Beertigger in forum Kilts in the Media
Last Post: 12th July 07, 07:22 PM
By sjrapid in forum DIY Showroom
Last Post: 4th March 07, 07:23 AM
By Rex_Tremende in forum General Kilt Talk
Last Post: 29th August 06, 09:19 AM
Last Post: 25th October 05, 01:53 PM
By ScottishKilts in forum General Kilt Talk
Last Post: 18th May 04, 06:53 AM
