19th September 07, 08:15 AM
Sorry, I don't really have anything valuable to add. I just found the vitamin "M" reference to Motrin, very funny. I'm going to have to remember that one (I use Motrin for my knees when I play sports).
Thanks for the laugh.
William Grant
Stand Fast Craigellachie!
19th September 07, 07:05 PM
 Originally Posted by turpin
Semi-glib, generally uninformed response to a reasonable question removed by it's author out of embarassment, and in deference to the thoughtful, detailed, complete, and exquisitely responsive post by Mr. Wizard that follows below.
I have resolved to try and refrain from posting useless responses to DIY questions about areas where I have less to offer than other members.
Steve, my hat is off to you.
Heck Turpin - Now I forget what you said...... But I don't remember taking offence from it......?
As to Steve's response - The tops!
The kilts are done, but I tried taking flix of them, and they don't look any different than before.
They feel different!
19th September 07, 07:11 PM
Active duty Marines, (which I no longer am!) tend to abuse their bodies more than the average person would believe. We popped those things, in 800 mg strength, just to keep going. The true name of ibuprofin was unknown to us, and I only learned that was the name after I retired.
We all called them vitamin M................... Motrin.
Sometimes, they still serve a purpose!
19th September 07, 07:15 PM
 Originally Posted by Pleater
If you have a household candle, or a fancy one for intimate dinners, just take a hot knife and slice off a small chunk - an inch is all it takes, then when you have threaded your needle just trap the threads, near the needle, under the wax and pull. It is best to do this on a craft (not polished) table or spare bit of wood/anything hard - not the best furniture!! Not your thumb either as the friction will eventually make it hurt.
Only use the length of thread you neeed for each seam, plus a couple of inches so you can tie it off easily. That means minimum effort for you/minimum wear on the fabric - both significant when doing a kilt.
I really must try a box pleated kilt one of these days - once I have worked my way through the heap of kilts in waiting.
Put it on the list.
Another great use for a household candle is to unfold your kilt, and gently rub the point of a hunk of candle in the inside of a pleat. Then iron the kilt. The pleats will stay sharp for much longer! - and no damage to the fabric!
This is not my original idea! Servicemen and women of every branch have been doing this for as long as there have been uniforms. The creases last forever.
--And it works for kilts also!
24th September 07, 06:28 AM
#15
 Originally Posted by James MacMillan
Another great use for a household candle is to unfold . . .
I have always found that the best (cheapest) candles for uses like this are found in the grocery store. In the Kosher food sections are Jewish sabath candles. They are very inexpensive compared to "household candles" You can take two and run the thread between them. Itwist the candles slightly so the tread does a lazy figure "s" between the candles. Waxes bothe sides and doesn't hurt the table.
Once the thread has cut the candles in to small pieces, melt then down, remove the wicks and pour into cup cake papers. Once cool reuse to wax thread.
Last Post: 15th April 08, 10:11 PM
By Rhys in forum Kilt Board Newbie
Last Post: 23rd June 07, 12:47 PM
By cloves in forum Miscellaneous Forum
Last Post: 17th March 07, 03:51 PM
By Heath in forum General Kilt Talk
Last Post: 1st April 06, 03:29 PM
By Bill in forum General Kilt Talk
Last Post: 8th August 04, 04:04 PM
