23rd November 07, 04:36 PM
To kind of reemphasize what Steve said. I wear all my belts just like on a pair of pants, with the one exception of the one buckle that would obviously be upside down it I wore it that way.
Adam
23rd November 07, 04:47 PM
Horizontally. Vertically is wrong. And awkward.
23rd November 07, 07:55 PM
MacDougall has the important point here!
Those of us who served in the Armed Forces, would have to re-trained to do it any other way....... Which in the case of Marines, might be more time than I have left on this earth, so I say the excess should go towards the left.
But really - Who gives a sh - wear it the way you want.
23rd November 07, 08:29 PM
I've wondered about this myself. I'd read many years ago that the Waiste Plate (buckle) was right hand and the loop on the left. I always figured it was because duty belts or Sam Browne belts have the permanantly attached buckle on the right and the hooks on the left. None of these belts are meant to go through belt loops so to keep the tab on the left hip you put the buckle on the right. Of course a conventional buckle belt would go anticlockwise as usual.
26th November 07, 06:50 AM
Actually there is a tradition. Weird but it is there. If you look at the waistplate buckles that have an up and down you will find that that the belt goes around yourself in the opposite direction that a trouser belt goes.
I noticed that the first time I wore a clan crest buckle myself. It was very disorienting, as it was opposite the way I had always worn a belt.
It doesn't even take much military time. I would say that if you went through basic training, you will have to retrain yourself. Even with civilian clothes, I find myself checking my "gig line".
26th November 07, 09:47 AM
HTML Code:
You can't beat that military training for inprinting things in your brain
Even though its been 36 years since I got out of the Army, I always check my gig line and still don't feel comfortable with my shirt tail out.
My plate buckle is made to buckle on thje right side so
tend to put on my regular buckle kilt belt the same way.
I noticed that if I put my belt on in the same direction as I wrap the kilt the the belt doesn't pull on the kilt and make the front apron bunch up
I'm an 18th century guy born into the 20th century and have been dragged kicking and screaming into the 21st century.
We do not stop playing because we grow old, we grow old because we stop playing"
25th November 07, 09:53 AM
interesting...... my Dad (who also taught me how to tie a tie....even though i'm a girl) always said that as long as the buckle has no up or down ...that you should always reverse the way you wear you belt every so often so the belt does not develop a curve.
I've been doing it that way ever since. Even with my big heavy Cavscout belt. It still hangs straight when I put them in the closet at the end of the day.
25th November 07, 10:11 AM
How would that even work? It still goes around the same space in the same shape, just different direction.
For that matter, all mine lay straight as well even though I don't switch them.
25th November 07, 10:42 AM
I learned to turn my belts also.
You are not a perfect cylinder so the top of the belt has less stress than the bottom where you are wider, as the belt stretches the bottom side stretches more. When you go the other way the belt is turned over so the top is down and the bottom is on top.
Mark Keeney
25th November 07, 10:53 AM
Would this not matter as much in kilts? Many don't use the loops (so not stressed) and it's not holding up the kilt anyhow. Although flipping does make sense with trousers.
By LadyGriffin in forum DIY Showroom
Last Post: 13th October 07, 06:25 PM
By John Fiske in forum General Kilt Talk
Last Post: 6th March 07, 06:25 PM
By ian in forum Professional Kiltmakers Hints and Tips
Last Post: 15th October 06, 08:05 AM
By JockEleven in forum Kilt Advice
Last Post: 14th September 04, 01:37 AM
By kilted in KC in forum How to Accessorize your Kilt
Last Post: 17th June 04, 09:32 PM
