Results 11 to 18 of 18
Threaded View
    15th January 08
    *610* PA
    Does this count??
    ...as an "X-Kilt?" Am I part of the club now??
    My Winter Camo Kilt
    Well, I decided to try my hand at Kilt-making and downloaded the instructions provided by the forum. The instructions are fairly simple and easy to follow. My only issue…what material to use and what color? I already own a Black Watch Tartan, I’ve ordered my Family Tartan, for which I must yet wait for - and a digital MARPAT Kilt made by AmeriKilt.com (which I use for paintball)…what I didn’t have was something specifically for winter…and especially for paintball.
    The instructions provided by the site are intended to create the “X-Kilt” that has 3” box pleats. That’s cool…it uses less material overall and seems easier to sew than a knife pleated Kilt. Since I’m sewing this by hand (no machine available to me), that should be less needle work.
    This made my choice pretty simple…white. Now the weight…hmm…playing paintball in the winter can get cold on its own…now wear a Kilt on a snow-covered mountaintop in PA. I chose to use 10oz canvas but I could only get it in off-white. No problem, paintball fields that I attend don’t normally have pure white snow.
    Looking at the instructions, the pattern calls for a doubled outer apron and a single layer inner apron. I chose to modify this and make both inner and outer aprons double thick. This would give me extra warmth while running around like an idiot in 20 degree weather. I purchased 3 ½ yards of material for $15.00 and a spool of matching white thread. I also purchased a pack of white ‘sew-on’ 3” wide Velcro. Since the material came ~60” wide, I knew that would be more than enough for what I wanted to do.
    I followed the recommendations offered on the instructions and first shrank the canvas in a hot washer and dryer. After plotting out the Kilt on the canvas, I cut the material into 2 sections 23” long (the drop of the Kilt). This way I could sew them end-to-end and have plenty of room to work with.
    As you can see, I sewed all the pleats (6 of them) into place…both inside and out. I also gave it a 3” over-hem at the small of my back. I will be using a 2” web belt and this way, the pleats are completely protected. What you don’t see is that the inside of that 3” over-hem extends down the inside to my rump…approximately 8” down to cover the “fell.” I also created a border for the tops of the aprons. This was 2” wide x 19” log (the length of the aprons from hip to hip) when I cut it and then folded it into 4 half-inch folds. This will keep the material from fraying on the top of the aprons.
    The bottom hem of the Kilt is the selvedged part of the material. Instead of stitching this, I used liquid thread locker to seal the threads together. It goes on clear and dries perfectly invisible. I also used it on all the stitches I made – in the pleats, the over-hem at my back, everything.
    I then stitched the Velcro on the over and under aprons but it runs the whole length of the aprons from hip bone to hip bone.
    The majority is done but I’m still working on creating an integrated sporran and finally, I will dye it to imitate PA hardwoods in the winter time. What I want to do is take Rit dye and mimic the barren foliage you see in the snow…tree limbs, sticks and shadows in gray…with just a touch of green (like rogue sprigs of grass coming out of the snow) and those purple vines from Hell.. How am I going to do that? Not a clue actually, but I was thinking that I could either make stencils from sticky plastic contact sheets from a stationery store or dip actual sticks and vines into the dye and imprint it directly onto the material.
    I have enough material left over that I want to make spats for my boots…and then dye them to match the Kilt pattern. This should blend better than a solid black boot does.
    Anyway, onto the pics…..
    All I have to do now is sew on the belt loops and create the sporran...then the dying thing I described above.
    How'd I do?
  1. Does this count?
    By Red Lioness in forum Show us your pics
    Last Post: 3rd March 08, 01:07 AM
  2. How to Count a Tartan
    By Scott Gilmore in forum The Tartan Place
    Last Post: 11th September 06, 04:25 PM
  3. I count my blessings...
    By Robin in forum Traditional Kilt Wear
    Last Post: 27th December 05, 07:38 PM
  4. Threads count
    By AckZel in forum Kilt Advice
    Last Post: 12th November 05, 05:50 PM
