Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Ah my friend, very rarely do you find that the price and the quality are at odds - and truly is it said that you get what you pay for.
    The suede effect is easily reduced by application water and wax polish, by the way, if that will improve things.
    The third strap requires that there is what is termed 'ease' in the circumference of the kilt so that there is enough room for the changes in the body as it sits, leans, slouches or accommodates large dinners.
    It might be that, with that ease, the kilt is actually loose when the wearer is standing in front of the mirror early in the day, so the strap is tightened up to fit the slim standing figure, and the apron then takes the strain later.
    Anne the Pleater
    I guess there's no way to put a stabilizer around from the third strap to the buckle, behind the canvas to take up the tension...
    That's why the second strap on the apron side (if a kilt has one) should be buckled loosely. And, as many have said, the second strap doesn't do anything, and the kilt hangs better without it (unless you're a dancer and need the second strap to control the flapping of the apron during dancing).
    22nd November 07
    US
    That makes sense, Barb.
    I'm at a point in altering my SWK where I am considering adding some kind of interfacing to the aprons. I might remove that strap and buckle in the process.
    My only other thought is to set that strap up so that it can be interchangeable (black/brown) and attached with an elastic loop to minimalize any pull on the apron. Maybe even a false strap that is not attached to the apron, but the under apron instead, would work.
    (It's a contemporary kilt after all.) Still thinking about how that might be done, though.
    20th August 08
    St. Paul, MN
    Yes, Yes
    I had ordered the Highland Express Straps and buckles as well and they are excellent. They will be perfect. Thanks for the suggestion.
  1. 2 straps vs 3 straps
    By be da veva in forum Kilt Advice
    Last Post: 11th June 08, 05:40 AM
  2. Source of good cloth
    By Martin S in forum General Kilt Talk
    Last Post: 19th June 07, 10:37 PM
  3. some good sites for you good people
    By Deasan in forum General Kilt Talk
    Last Post: 1st June 07, 04:58 AM
  4. Good sport kilt, good dog
    By Roan Carter in forum General Kilt Talk
    Last Post: 2nd February 07, 09:59 PM
  5. The straps don't lie...
    By Robin in forum General Kilt Talk
    Last Post: 12th September 06, 03:55 PM
