Results 11 to 20 of 54
    11th April 11
    Chicago Area
    Re: Tartan of the month - November: What do yo see?
    Other than the red the colors are very dark , blue , green and maybe black. possibly industrial dye.
    kiltmaker and tailor
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    And are those reflections from this being mounted under/behind glass, or are they wear/age/soil marks?
    The suggestion of a jacket underarm seems logical, from a relatively fitted design.
    An excellent observation. Reflections indeed. And seams too.
    CopperNGold is offline Oops, it seems this member needs to update their email address
    22nd September 11
    Oregon Coast
    Tailoring seam. Would this be worn during the day or at night? Here's a very wild guess. A shooting or stalking jacket?
    Once again, I know nothing...
    25th December 08
    Lotus Land
    ... the blue seems asymmetrical, appearing only to one side of the thin red line.
    I will assume that the pale blue thread isn't intentional, but simply a less dark part of the thread from a darker Blue spool.
    2nd January 10
    17 Post(s)
    Quote Originally Posted by xman View Post
    That is an incorrect assumption. It's ment to be there.
    8th August 11
    43N by 123W, Olympia, WA.
    Question Re: Tartan of the month - November: What do yo see?
    I see what could be the apron stitch and a Kilt with the bottom at the top of the picture????
    22nd September 11
    Oregon Coast
    Is the pale blue line a hand stitch? If it is, the contrasting color might be meant to stand out? A tailor's mark of some kind to line up the stripes? Is it removable, like a fine basting stitch?
    16th January 06
    London
    Quote Originally Posted by CopperNGold View Post
    If you look closely you can see that it is possibily 4 threads wide and there is a crossing of it with 4 blue threads on the right side of the picture as well, so definately meant to be there, and not designed to be removeable,
    sometimes it helps with these examples to copy into an image programme where you can then enlarge and also change the colour balance, which usually helps to make things clearer
    25th December 08
    Lotus Land
    Quote Originally Posted by paulhenry View Post
    If you look closely you can see that it is possibily 4 threads wide and there is a crossing of it with 4 blue threads on the right side of the picture as well, ...
    Quite right, thank-you.
    22nd September 11
    Oregon Coast
    Thanks, PaulHenry. I'll do that. My laptop doesn't show much detail. That's right, I blame it on the laptop!
  1. Tartan of the month - September: What do yo see?
    By figheadair in forum The Tartan Place
    Last Post: 22nd September 11, 09:41 PM
  2. Tartan of the Month - August: What do you see?
    Last Post: 27th August 11, 08:39 AM
  3. Tartan of the Month - May. What do you see?
    Last Post: 4th June 11, 05:41 PM
  4. February - Tartan of the Month
    Last Post: 27th February 11, 01:32 AM
  5. January Tartan of the Month - What do you see?
    Last Post: 15th January 11, 04:05 AM
