Results 11 to 20 of 23
    8th May 10
    Kent, OH
    Re: Doodling with a Sett
    I like the overall effect, but Barb has a point. It would be rather difficult to pleat to the sett with all those little lines "in the cluster" without diminishing lines. It has a classic look to it and the color choices are very nice. I'd be happy to pleat it to the red stripe and be done with it. I think the cluster colors would be too far into the back of the pleat to flash much, if any, really.
    Wouldn't it be nice if there were a special place Barb could keep all her threads? I think it'd be great to have a place for just tartan design and discussion. Scotweb wouldn't know what to do with all the business.
    Keep up the great work, Ian!
    Jon
    Only 9 notes. How hard could it be?
    5th October 11
    Eastleigh, Hampshire
    Had another play with the sett and came up with this
    Lost the little fiddly lines and not sure if I have lost the spirit of the first version. Still keeping the base red and green for Wales, the blue and white cross from the Saltaire, the Royal Navy element and the yellow and red from the Griffiths crest.
    Further comments more than welcome.
    Ian
    8th May 10
    Kent, OH
    Hi Ian,
    This is so different looking from the last. In my humble opinion, I'd tighten the cluster edges back up, because it looks as if you've got a secondary over check pattern now. The eye doesn't settle on any one spot like it did in the last example. Your colors are great and I think the extra bit of width in the blue in the cluster hit the mark. I hope you saved a copy of the last one. You may need it. Beautiful work!
    Slàinte,
    Jon
    PS: Just as a suggestion, try putting brown guard lines (single row/both sides) right next to the red (between the red & green) and see what happens. If you've got the time and want to play, try it with black or white guard lines, too . . . just for the heck of it. Then let me know what you think.
    Quote Originally Posted by MacIllfhilidh View Post
    Actually, Steve just made me a section of the forum for just that. It's under Professional kiltmakers Hints and Tips.
    8th May 10
    Kent, OH
    @Barb; Oooo, thanks! (Thanks, Steve!) Now we're talking!
    @Ian; If your set size is only 6.5" you can grow the center of the cluster without too much trouble and not drastically alter the feeling. If after increasing you find the green & red losing out, just throw a few more lines to each. It should work out OK. Just remember to keep back-ups of your work so you can go back if something isn't working for you.
    Jon
    16th January 06
    London
    From a kilt makers view, that would offer many options of pleating, and because of that it works better. I suspect that the white tram lines might appear very contrasty when pleated.
    There is always a matter of subjectivity on any tartan design, and also one of compromise to get something that works with a kilt, and yet still keeps the designer happy!
    5th October 11
    Ok, taking the last two comments on board. Trying to remove the overcheck and make the tramlines easier to pleat.
    How about this.
    I really appreciate this, guys.
    Ian
    8th May 10
    Kent, OH
    Oooo, thanks, Ian!
    I think you're onto something now, but wait for Barb to see what she thinks before you get too much farther along. My only worry is that going back to too many small stripes at the center of your cluster has made it difficult to pleat to the sett again. ? ? ?
    @ PaulHenry: "Tramlines, eh?" I love it!!! I'm going to use that next time! It's great! Cheers!
    Jon
    16th January 06
    London
    "tramlines" it's not my original use, but thank you!
    I think I still favour number 2 to number 3 but they are both easier to work with than number 1
    I like the look of #3 (has more of the feel of #2), and the spacing of stripes should make it much easier to pleat. Just to make sure, though, can you tell me what's the width from the outer edge of the red to the outer edge of the red in the cluster of stripes at the pivot?
  1. Sett size??
    By Spartan Tartan in forum General Kilt Talk
    Last Post: 8th November 11, 04:44 AM
  2. Replies: 38
    Last Post: 28th November 09, 06:13 AM
  3. Full Sett and Half Sett?
    By pauljsharp in forum Kilt Advice
    Last Post: 17th May 09, 08:05 PM
  4. Sett vs. Stripe
    By Barb T in forum General Kilt Talk
    Last Post: 21st December 06, 04:11 PM
  5. Sett Size ?
