Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
    22nd November 06
    Quote Originally Posted by Dreadbelly View Post
    If your kilt is measured to exactly 40 inches, sitting will place a lot of strain on the seams, and could cause some real problems.
    This is fine if the kilt is intended to fit best when seated. A properly fitting kilt should be quite snug. If its measured to hang around one's rear it will hang and not be snug. Kilts are not muumuus or burlap sacks. A kilt is a fitted garment. For best freedom of movement its best to have the kilt, as tradition puts them, sit high. This cut is generally ill-suited to women. It won't work. Forget it! Don't want to sound like a sound-bite from Al Bundy in "Married with Children" but..
    ALWAYS SIT DOWN WHEN MEASURING YOUR HIPS.
    Standing, your hips might be 40 inches. Sitting, you can expect to add several inches to this figure.
    Well, a kiltmaker takes this into consideration somewhat by measuring somewhat loosely at the hips over a pair of pants. The waist is measured somewhat more snugly over a light shirt.
    As I said before, DO NOT fudge or adjust the measurements if a kiltmaker gives you specific measuring instructions. If you do, your kilt will not fit properly.
    And there's really no strain on the fell when you sit down. How could there be? The only place that the kilt is held together is at the waist and hip buckle. The hip buckle is placed several inches about the bottom of the fell, so sitting really isn't a problem.
    Barb
    16th December 05
    Maryland USA
    For my own kilts, I measure the back of my waist
    from where I want the pleats to start to where they
    stop. I do the same for the hips. The difference
    between these measurements is how much I
    make the pleats taper in the fell.
    For the front I measure around the entire waist.
    What isn't covered by the pleats like I described
    above is made up with the apron.
    I could measure the front using the same method
    as I described for the back, but it is too easy to
    not get the tape measure on the same exact
    spots, and have a wrong size kilt.
    By the way, the reason I do it this way is because
    my waist sticks out in the front as much as by
    butt sticks out in the back, giving both the
    waist and hips the same measurement even
    though I am not cylindrical shaped.
  1. UK Versus FK
    By NancyMan in forum Contemporary Kilt Wear
    Last Post: 27th June 06, 01:04 PM
  2. Sporran placement on the hips
    Last Post: 15th December 05, 03:08 PM
  3. 4 yd. 16 oz. versus 8 yd. 11 oz.
    Last Post: 1st October 05, 02:55 AM
  4. evening out the spacing on the side of your hips
    By swat88eighty in forum Kilt Advice
    Last Post: 30th October 04, 12:33 PM
  5. Pleats versus wrap
    By ggibby in forum General Kilt Talk
    Last Post: 9th March 04, 01:22 PM
