10th July 09, 04:39 PM
#21
 Originally Posted by McNulty
I used to have an F150 Extended cab and sorta like McMurdo I use the waist belt from an old bathrobe. I'd sit sideways, swing in, lift my butt, and put the waist belt behind me and under my butt. After turning to face the front I'd pull the belt forward while lifting my bottom slightly. The bathrobe waist belt smoothes out the pleats and no bunching. Even works in my wife's Subaru. I now store the belt in the compartment between the seats.
Nulty
A+ for you as well!
11th July 09, 06:40 AM
#22
I have a truck as well - I am of the step on the running board, butt in and sweep persuasion. Seems to work well. In my wife's car however, I have a bit of a drop before I hit the seat and this can mess up the sweep part. I sometimes find I have to do a rather inelegant reach between my legs and pull the pleats out so they don't bunch up under my butt in a very uncomfortable manner. I might try this belt sweep thing however. Seems like a simple solution.
11th July 09, 08:15 PM
#23
 Originally Posted by Chas
Corey - Since my last post, I have done some thinking and a bit of experimenting. What I have found is this:
A towel doesn't work for me - too plush, too thick (interacts with the kilt too much).
A tea-towel on the other hand does work. I am working on putting a loop in each corner, so that after sitting and turning forwards, I will be able to pull the tea-towel out. This should act a kind of pleat sweep. If it works, I'll look round for a dark coloured tea-towel to modify (I think it would look better than a light coloured one).
Chaz
You can pull the towel out from under you once you are in the seat, the kilt is bulky enough without the added bulk of a towel as well.
By BEEDEE in forum Miscellaneous Forum
Last Post: 15th June 09, 10:06 AM
By alhrensblade in forum Kilt Advice
Last Post: 28th October 07, 08:25 AM
Last Post: 15th March 07, 08:48 PM
By BonnieT100 in forum Kilt Advice
Last Post: 14th June 06, 06:10 PM
By Will Macadam in forum Kilt Advice
Last Post: 18th July 05, 09:54 AM
