Results 21 to 30 of 39
    1st December 06
    Conyers, Georgia
    19 Post(s)
    It's OK to replace the toorie with a black one if you like--I like it personally, but I have two balmorals, one with red and one with black.
    Also, take the bonnet, get it really good and wet in the sink, squeeze (don't wring it) the water out as well as you can, then put it on and shape it soemwhat. Remove it from your head, and then let it air dry.
    You'll like the looks of a well-worn bonnet, and over the years it will take on more and better character. A bonnet should be kind of loose and floppy.
    Jim Killman
    16th September 08
    Charleston SC
    Quote Originally Posted by thescot View Post
    This bonnet is from the late 60's early 70's its just not been worn a lot. If i try the soak it method, ill never be able to wear it again. Its already 1/4 size to small .
    17th March 07
    Harbor Springs, MI
    Quote Originally Posted by Kilted Rogue View Post
    It may not be worth it for one hat but if you have a few smallish hats you're trying to wear, you might consider getting a hat stretcher.
    I got one and was able to reclaim a Balmoral from my younger days that was a bit small. Just steam or soak and let it dry on the stretcher.
    BTW, in case someone doesn't know (not likely on this site!), historically the toorie was the same color as the rest of the bonnet, simply the tufts of yarn at the end of knitting the bonnet. It ended up being the Highland Regiments that color coded them for the various units as part of the uniform.
    Ken
    "The best things written about the bagpipe are written on five lines of the great staff" - Pipe Major Donald MacLeod, MBE
    Quote Originally Posted by HarborSpringsPiper View Post
    That's interesting. I've only seen red touries on regimental headgear. (The only exception I can think of being perhaps the London Scottish/Toronto Scottish with their rather oddly coloured dress.) Do you have images that show this?
    Anyhow I too think the navy Balmoral with red tourie looks a bit out of place with that Ukilt...I don't know why, but to my eye anyway that sort of Balmoral looks "trad" and wants to go with a trad kilt.
    I would wear a black Balmoral with black tourie with the black Ukilt. That sort of Balmoral is somehow more universal and can more easily go with various forms of dress I think.
    17th March 07
    Harbor Springs, MI
    I'm not sure if I can produce any images but should be able to produce some credible sources. I'll take a look in a couple of books I have later that I believe make mention of this.
    A quick google produced this:
    The 84th were to be "...cloathed and accoutered in like manner as the 42nd Regiment..."
    (Black Watch), but with these differences. They wore a blue torrie in their bonnets, they had a distinctive regimental lace, and retained their broadswords.
    From "84th REGIMENT OF FOOT
    2nd BATTALION
    ROYAL HIGHLAND EMIGRANTS
    1775-1783" p. 2: http://www.kingsorangerangers.org/im...84_history.pdf
    Ken
    1st December 06
    Conyers, Georgia
    19 Post(s)
    I didn't mention to use only cold water and tug it at the headband before you put it on and then set it down to dry. Water won't shrink wool; heat will.
    Jim Killman
    1st December 06
    Conyers, Georgia
    19 Post(s)
    One less than traditional option that you might consider is a beret. It doesn't really look out of place with a kilt--it's probably a derivative of the bonnet--but it's not so trad looking if that's what you are concerned with. You can find some pretty good photos of Pinache in a beret that will give you a good idea.
    Personally, I still think the balmoral is a good look for anything you wear.
    Jim Killman
    20th December 04
    Charlottetown, PEI
    in this case though a red torrie looks fine...it's balanced by the shirt color
    16th September 08
    Charleston SC
    Quote Originally Posted by cloves View Post
    I thought the same thing, while i was out walking, i considered red flashes, to break the black up.
    No i am not going for a trad look, I just want to wear my bonnet.
    And at 24 dollars i may pass on the stretcher. See if a local hat shop can do it,
    10th February 05
    Seattle, WA
    Looks good Kilted Rogue! It's not traditional, but you're not trying to be.
  1. History of Contemporary and Non-Traditional Kilts?
    By Bugbear in forum Contemporary Kilt Wear
    Last Post: 28th September 09, 05:48 PM
  2. Sporrans with contemporary kilts?
    By Alaskan Kilted Guy in forum Contemporary Kilt Wear
    Last Post: 9th June 08, 11:10 AM
  3. Advice on contemporary/work kilts..
    By Arlen in forum Kilt Advice
    Last Post: 2nd April 07, 11:13 AM
  4. Pipeband with contemporary kilts?
    By Raphael in forum General Kilt Talk
    Last Post: 24th September 06, 05:29 PM
  5. Kilt Jackets with Contemporary Kilts
    By Geoduck in forum How to Accessorize your Kilt
    Last Post: 8th June 05, 04:23 PM
