Results 21 to 30 of 39
    I was taught that, if the stitches are more than a pencil point apart, it's too far. So every 3/16 or 1/4 isn't nearly close enough, and the stitch points will show as soon as there's a little tension on the pleats.
    The only way to get the stitches close together without doing a stab stitch is to be able to flex the cloth. Here's a photo that illustrates what I mean by "flexing the cloth". You'll see that the needle is almost horizontal (not going vertically up and down through the fabric), and the cloth is flexed over my left index finger to allow the needle to accomplish this while at the same time going through all four thicknesses of 16 oz tartan in one motion. It also means that your index finger gets poked a lot until you develop a callus (and sometimes just below your fingernail on your left thumb.....ouch). You can also see why you only pin one pleat at a time. If you had more than one pleat pinned, you wouldn't be able to get your fingers over the edge of the pleat without having a huge bunch of material in the way. For those interested, the tartan is Ancient Duncan.
    A hoop isn't a good idea. If you are stitching in a hoop, the only way to get stitches close together is to do a stab stitch (i.e, down and up in two separate motions), because, when the kilt is tight in a hoop, you can't flex the cloth.
    BEEDEE's Avatar
    BEEDEE is offline
    8th January 07
    Tinopai, New Zealand
    I was privileged to recently see the Highland Granite Tewksbury that Steve Ashton has. The stitches are so close together that you can't see them unless you flex the material. Thy really are close together.
    Brian
    7th February 08
    Abbotsford, BC, Canada
    OK, I think I've finally got it (thanks to the photo/scan Barb posted earlier, in this thread - I'm a visual learner, and having a print like that, in front of me was a great aid!!) :
    pleats "test" pinned - and i also went over my chalk marks, with thin, white, basting thread , as i find the chalk fades
    now I "just" have to sew the pleats ( properly) ... but for now, i think i hear a cold stout calling ...
    Yup - that will work. Just remember that you'll pin only one pleat at a time when you're actually stitching the pleats.
    7th February 08
    Oh, I WILL!, I have NO desire to be my very own voodoo doll! - besides, i REALLY only want to have to sew each pleat ONCE! ( and thanks , once again, for your valuable tips!)
    15th April 07
    State College, PA
    Hi Barb,
    I am interested in the method of pinning. Do you pin perpendicular to the pleat you are sewing like the pinning at the waist that you mention in the book?
    Thanks,
    Wallace Catanach, Kiltmaker
    Yes - perpendicular to the edge. That's the only effective way to anchor the stripes. If you pin parallel to the edge, the top layer of cloth can skooch and slide out of alignment.
    Here's what I do:
    -I thread and needle and wax the thread.
    -I pin at the waist first, then add two pins between there and the top of the kilt, making sure that there's just a little flare from the waistline pin to the top. We're not talking much, here - maybe a 32nd. Enough to let you flare it a little when you put on the top band. Oh - and I also pin the waist about a 32nd smaller than the actual measurement, because the pleats tend to expand a little at the waist when you stitch (not true at the hips).
    -Then I clamp the tartan under my leg, measure the pleat width at the hip, come up from the bottom with my needle and thread, and then go down and back up again to lock the bottom of the fell so that the knot doesn't pull through. Then I put the needle into the tartan like a pin to hold thing aligned at the bottom of the fell.
    -I give a good tug and go to a spot midway from the bottom of the fell to the waist. Being the anal person that I am, I typically measure this, too, to make sure that it's consistent from pleat to pleat, and I use a pleat width midway between the waist and hip pleat size. I make sure that what needs to be centered is centered, and I put in a pin perpendicular to the edge and right at a prominent color boundary.
    -Then I give another good tug and add pins perpendicular to the edge at some of the color boundaries along the rest of the pleat, again making sure that things that should be centered are centered.
    That's it!
    7th February 08
    just so folks know, I finally finished this kilt, yesterday afternoon; Thanks for all the help ( esp. Barb!).
    As many have said, on this forum before, it certainly gives one an appreciation for the work of the professional kiltmaker! What a LOT of work!! It has been a real "learning experience"!
    It turned out alright, for a first time hand sewn "tank", but I know & see the mistakes, that aren't apparent to most others - but I also know much more about what I will & won't do, on the next one!
    Got a number of compliments about it already, when I wore it 'out'.
    ( Also recommended "THE BOOK"/TAoKM to a mom, as a perfect christmas present, who told me her son would be "so jealous", if he saw my kilt, as his doesn't fit anymore & he he "wears it everywhere"!)
    Starting another 'x-kilt' style kilt soon/next, before starting my next hand sewn traditional ( MacNaughton Ancient tartan, this time).
    Congratulations!
    1st December 08
    Montgomery Alabama
    6 Post(s)
    Quote Originally Posted by jhockin View Post
    ............. it certainly gives one an appreciation for the work of the professional kiltmaker! What a LOT of work!! It has been a real "learning experience"!
    It turned out alright, for a first time hand sewn "tank", but I know & see the mistakes, that aren't apparent to most others - but I also know much more about what I will & won't do, on the next one!..................
    Hmmmmm,
    very telling that last bit.
    Definite signs of KMM (Kilt making Mania), the OCD characteristics the arcane jargon.
    Very sad; a tragic result of playing with addictive substances (worsted wool, why even the name is ominous, why not BESTED wool). So difficult to stamp out actually, we medical types are aware that this stuff actually grows NATURALLY on some domesticated animals).
    This one has a grim course unless he may summon the depth of character to break free from his new addiction.
    So sad, the side-long glances, the whispered conversation, "drug (this wool stuff)-seeking behavior," mysterious packages from off-shore with names like "Marto-Jura," "Strome" etc (I believe they represent the potency of this wool-drug), needle marks,spare threads on his clothes, sleepless-ness and red-eyes are a give-away to the observant. It leads to the blank stare, myopia and muttering of some sort of secret mantra like ("5/8 or 11/16; 5/8 or 11/16!")
    I suggest a withdrawal program (doing only 13 oz boy kilts in progressively larger setts and smaller boys) until one happy day he is able to slowly back away from the needle to which he will have been for so long enslaved.
    May you find joy in the wee, ken the universe in the peculiar and capture peace in the compass of drop of dew
  1. Full Sett and Half Sett?
    By pauljsharp in forum Kilt Advice
    Last Post: 17th May 09, 08:05 PM
  2. Sett Size
    By Jack Of All in forum Kilt Advice
    Last Post: 8th June 08, 04:46 AM
  3. Pleating to the sett - How?
    By cacunn in forum DIY Showroom
    Last Post: 28th February 07, 02:47 PM
  4. Box pleating to sett! How to . . .
    By MacWage in forum DIY Showroom
    Last Post: 11th January 07, 08:34 PM
  5. Help with pleating to the sett
    By Kilted Taper in forum DIY Showroom
    Last Post: 6th December 06, 02:32 PM
