Results 1 to 10 of 29
    21st August 10
    North Carolina
    Great Kilt Question
    Hello all!
    I am doing a speak for a public speaking class, and my topic is the evolution of the kilt. I wish to wear a historically accurate great kilt. I have a length of fabric, 6 yards long. But this fabric is only 45 inches wide. I am a small guy, but pretty tall. Should I cut the fabric into two 3 yard pieces and sew them together to create one 3 yard by 90 inch piece of cloth, and then trim it from 90 inches to around 60 inches?
    Any help is appreciated!
    17th December 07
    Staunton, Va
    I don't think you have enough fabric to do an historically accurate great kilt. According to most sources the plaid was about six ells of double tartan-- in other words it was about 5 feet wide and about 18 feet long.
    If you have a kilt that matches your length of fabric, you might want to consider making a "top piece" that would give the impression of a great kilt, and which could be removed during the lecture to show how the kilt was transformed during the 17th century.
    21st August 10
    North Carolina
    That is a great idea! But i really wanted to show them "the real deal", along with pictures of how it is worn improperly. I mentioned that I'm a skinny bloke, about a 29 inch waist, so I thought 3 yards could be enough. Or perhaps I shoud just get 8 yards of single width fabric and end up with what you say, 18 feet.
    30th June 10
    San Francisco, CA, USA
    If you want to be totally "historically correct", of course, you'll want two lengths of single-width tartan sewn together. As a matter of convenience, though, you might want to just use double-width fabric and mention it verbally during your presentation. If you haven't seen it, you might also want to check out Matt Newsome's article on the possibility of the "great kilt" having been worn with loops and a drawstring: http://albanach.org/drawstring.htm
    Length-wise. . .I have a 34-inch waist and have found a length of 4 & 1/2 to 5 yards of double-width tartan quite sufficient.
    8th June 04
    Port Crane, New York
    Quote Originally Posted by Dale Seago View Post
    I'm becoming more and more a fan of the drawstring theory for plaids, or even more simply a series of belt loops sewn on at waist level. The notion of clansmen flinging their plaids out onto the wet or muddy ground to put them on seems wrong (though of course they did roll up in them to sleep on that same ground!). Who knows?
    I want to try the belt-loop theory, though. It seems it'd be a simple process to stand there feeding your belt through a number of loops on a plaid, scrunching the fabric as you go (somewhat in the manner of a shower curtain on its rings). Once you have all of the tartan wadded onto your belt (it would sort of pleat itself), you slip on your dirk and sporran, fasten the whole affair around your waist, adjust the aprons in front - and you're good to go!
    Sound reasonable...?
    Brian
    8th June 04
    Actually, not 6 ells of double tartan, but 6 ells of tartan doubled, for a total length of 3 ells, or about 3-3.5 yards total length - depending on whether you're talking about Scottish (37") or English (45") ells! This was the size plaid issued to Highland enlisted troops in the British army. Civilian plaids could be a bit more generous, but usually no more than 5 yards.
    Remember, the tartan fabric came off the hand looms about 27" wide, so two lengths had to be joined together lengthwise to make the completed plaid, with an approx. 54" width. So, 6 ells of tartan yields a 3 ells in length plaid.
    Brian
    30th June 10
    Quote Originally Posted by Woodsheal View Post
    That was my understanding too.
    18th September 08
    Northern Virginia
    My understanding as well and basically how I wear mine. I've found that 4 yards of double-width fabric is quite adequate (and more comfortable over the course of a long day).
    Fabric of only 45" in width may not be quite adequate, but you could easily try it on and see. I've used fabric only 47-48" with some successs though the "plaid" section was a bit on the small side though it would certainly work for demonstration purposes. You should gain an inch or so by keeping them hem a few inches above the knees, which is also more historically accurate.
    US Marine (1970-1999)
    17th December 07
    Staunton, Va
    Thanks!
    That certainly makes more sense! Interestingly, three different sources mention the 5x18 foot size-- obviously somebody back then didn't do their A Levels in math!
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    Wwwwwweerr
    Loudoun's Highlanders were issued 12yds to make a plaid. 3 yds is too little to be effective if one is living & working in a plaid. The Highland troops comlained when financial restrictions caused the government to reduce the amount of cloth from 4 to 3.5 in the late C18th. I've recently examined a civilian plaid c1700-20 that is 18' (6yds) long. I suspect that older plaids were longer & at least 4yds in order to be practical.
  1. Question about the Great and Small
    By ThinBlueLine in forum Historical Kilt Wear
    Last Post: 7th May 10, 08:55 AM
  2. Great Service, great stuff from Sockdreams.com
    By BroosterB1 in forum How to Accessorize your Kilt
    Last Post: 29th November 08, 07:37 PM
  3. Converting great kilt to trad 8 yard small kilt
    By gilmore in forum DIY Showroom
    Last Post: 17th July 07, 04:13 PM
  4. Great Kilt
    By Southern Breeze in forum Kilt Advice
    Last Post: 7th March 06, 02:03 PM
  5. great kilt
    By switchblade5984 in forum General Kilt Talk
    Last Post: 17th November 05, 04:54 AM
