Results 21 to 30 of 38
    Re: The Video Thread
    OK, Eric...hammer. Three things.
    1. catch the ball even further behind you on the right. SUPER exaggerate that. Reach back behind your to "catch" the hammer as it comes around. This gives you a longer arc through which you can accelerate the hammer.
    2. good job, you're not busting a gut to wind it fast on the first and second wind. That gives you somewhere to go with the third wind. But then, when you get to #3, you gotta GO. Pull the snot outta that thing, fast, fast, fast.
    3. Head up at the delivery. Seriously, look straight up in the air. Look at your video. Now look at these pictures.
    Dan McKim at Enumclaw
    HB III
    http://www.flickr.com/photos/gertie_du/3800845690/
    Dan McKim, again
    Adriane Blewitt
    Look straight up into the sky as you pull to the finish. Watch Heather MacDonald, she has kickbutt hammer delivery. If she'd slow down her first wind and quit laying back as she pulls, she'd have 90 foot hammers, easy.
    and finally...totally insane picture of my mentor...Mike Pockoski, just for fun
    HOW NOT TO DO IT.....
    I actually know this woman...nice gal. I like her. But rotten hammer delivery.
    20th June 11
    Huntington Beach, CA
    Awesome Tips, Alan!! Thanks - can't wait to try to implement this on Sunday!
    14th June 10
    Cali
    You're also pulling in (short-arming) your hammer release.
    Seeing as how you're using DBs for throwing weights, is it safe to assume you don't have any throwing weights? If yes, we can show you how to make some of your own from weight plates, sched 80 pvc, hardware fittings (washers, nuts, 5/8" bolts), chain, quick links or shackles, and such.
    Here's an example of the type of weights I build...
    This is a 16 lb chain handled hammer. It's a training tool that teaches you throw with your hips rather than your arms (full body winds as opposed to "arm-winding"). This was the only picture I had of my weights that was easily accessible. I can post more later.
    Key to this construction is the eye-bolt and the shackle which can bought at any industrial fastener shop. Chain can bought most cheaply at garage sails but Home Depot or Lowes may do in a pinch.
    Oh, the 3/4" sched 80 PVC goes around the 5/8" eyebolt shaft and just fits inside a weight plate. Makes everything s o l i d.
    The handles may prove to be a problem. If you weld or have a friend who does, you can make your own. You can buy handles mail order for about $20 a piece plus shipping from Bobby Dodd (Mjolnir Hammers Ltd/ Hevy Gear).
    Once you get the hang of building practice weights, you make them any size/weight you like. I train with underweight implements to work on speed. You cannot buy an underweight 28 or 56 but you can build one. I have 25, 28, 35, and 42 lb throwing weights. Same thing goes with hammers. I have 10, 12, 14, 15, 16, 19, and 22 lb hammers.
    When you get some decent practice weights, I'll show how to use the traffic cone in a technique drill.
    20th June 11
    o1d_dude - Thanks a TON!!
    I built this today, found all the parts at Lowe's, the total was just under $25. I'll order a D-Handle for Light WFD from Mjolnir. BTW, they're $30, not $20...
    Can't wait to try it out...
    Thanks again!
    20th June 11
    Here are some videos of me from Queen Mary Games on Saturday:
    56# Weight over Bar - 11'
    22# Heavy Scottish Hammer - 72'
    56# Heavy WEight for Distance - 24'9" - this ones a BITCH
    22# Braemar Stone - 30'2"
    14th June 10
    Cali
    Looks like you had nice weather down at the Queen. Last time I was there, it snowed on the Grapevine and from the Queen you could see snow on all the moutain tops.
    Anyway, here are a couple of things I noticed in your videos.
    1. In the hammer video you are set up with your heels almost against the trig. That's a bit too close even if you were wearing spikes. Without spikes you should stand about 12-18" away from the trig so you have room to recover after release. With that much recovery room, you will be able to throw with more "violence".
    2. In the Widowmaker (HWFD), your technique is fine right up until the second spin. After the first spin, you're stepping through the rotation which slows you down. Ideally, you go slower in the first spin and accelerate the second. Go back and watch the video. See how first your right foot steps and is then followed after a second or two by the left foot? You want to imagine your shoelaces are tied together and try to get both feet down as almost-simultaneously as possible. STICK the left foot down so you can push with the right hip to accelerate the weight.
    3. The stone looks pretty good. Just make sure your right hip leads your right shoulder. That's the dreaded "X-position" and is analogous to drawing back on the bow for power.
    Good effort and you've got a lot of potential that you haven't tapped into yet. That's a good thing! Harness it and throw far.
    12th April 11
    Orange County, CA
    @Eclarkhb
    Yup, can see that the First Place mug was properly awarded!
    CONGRATULATIONS!!!
    Whoa, those cars look like they're in the danger zone, they didn't seem so close.
    20th June 11
    Quote Originally Posted by GoodGirlGonePlaid View Post
    @Eclarkhb
    CONGRATULATIONS!!!
    Hey, I saw you got some medals as well this weekend! Congrats to you too!!
    The cars were about 200' away, so they look closer in the pictures, they weren't in danger.
    20th June 11
    Quote Originally Posted by o1d_dude View Post
    Thanks for the tips - I appreciate it!
    Two thumbs up on everything....just SO much better than Ventura. Now you get to go get beat up in the B's for a while!
  1. Companion Comment thread-Poet Laureate Challenge or the limmerick thread
    By ForresterModern in forum General Kilt Talk
    Last Post: 12th May 09, 09:36 AM
