13th February 08, 08:00 PM
Thanks Moosedog. That thread looks like it will help a lot. Glad you posted the link here.
21st February 08, 05:38 PM
I might have to find a different person to do the work on that corduroy jacket and vest conversion for me. It's a little difficult for me to know what is supposed to be done.
I'm starting to look around on a few different sites for the brown hose. I like good thick wool or wool blend hose. I've been calling them wolly lamb leg hose... I'm not so sure what "snuff" colored is, but I'm not seing that term anywhere.
I might look for a second pare of shoes that are leather dress shoes or something on that line... I can see now how different parts of the outfit can be changed out for variety centered around this kilt.
22nd February 08, 12:31 AM
One kind of hose I'm thinking about going with for this outfit is the Lewis Kilt Hose from The Scottish Tartans Museum.
http://giftshop.scottishtartans.org/hose.htm
They do have these hose in brown. That would be a wool acrylic fifty/fifty blend, so they are woolly lamb leg hose...
I should probably think a bit about the color of the flashes with the brown hose. I have maching tartan flashes that might work, but I might also pick a color out of the kilt and go with that contrast. I might also look over my color charts and see what might go best against the brown... I'm going to have to get some sighted help for that part I think.
I have been playing with the idea of having flashes made from the corduroy that is being removed from the jacket, but I don't know if that would work so well. I might have that material made into a driving cap. It would probably be best to look into getting traditional garter ties from The Scottish Tartans Museum.
* I need to store this somewhere so I can find it later.
2 inches is about the maximum amount you can take in a tank without throwing off the look of the kilt. But it can be done quite simply.
The first step is to put on the kilt without putting the straps through the buckles. Insure the kilt is on snug but not tight and that the waistband is aligned along the top. Have a look in a mirror to check that the kilt is hanging correctly, the pleats are not splaying and the apron not puckering.
Mark the kilt on the buckle side with a piece of sharpened blackboard chalk along the edge of the outer apron from waistband to the bottom of the Fell. This is where the apron will lay after you reposition the buckles.
Now with a sharp knife, seam ripper or scalpel cut just the stitches fastening the tabs that hold the two buckles on the right side and also cut the stitches that sew the left strap to the under apron. DO NOT CUT OFF THE LEFT BUCKLE!
Put the two right buckles onto the right side straps using the center hole. Lay the kilt out on a table as if it were fastened on you with the area where the buckles go on the top and centered in front of you.
Bring the outer apron over until it is aligned with the mark you made and with the chalk mark the new position of the two buckle tabs. This is the new location of the tabs and where you are going to carefully sew them back on.
Use a good quality polyester thread, such as Gutterman, in a color that matches the color of the buckle tabs. Use little tiny stitches and try to make them as close to the edge of the tabs as you can. The idea is to catch just a couple of yarns with each stitch and make them as invisible as possible.
Once you have the right side buckles re-attached put the kilt back on with the center hole of the loose left strap through the buckle and also through the hole in the waist.
You will now make a mark on the front of the under apron where the end of the strap now aligns. You will need to push the outer apron down and out of the way to mark the under apron and it helps if you have one of those big spring alligator clips or a real strong clothes pin so you can do all three things at once. (pinch the strap in position to the inner apron, push the outer apron out of the way and make the mark with the chalk.)
Now all you have to do is sew the left strap back onto the front face of the inner apron. (yes, it is going to be moved from the edge of the under apron to some where on the front face.) Make three or four passes of the thread through each hole in the strap. This sewing needs to be strong because this is where the most stress is when you cinch the kilt on everyday.
That's basically all there is to it. Remove and reposition the two right side buckles and remove and reposition the left side strap.
If your kilt has sporran loops on the back you will find that they may now be off center. You can simply cut them off and throw them away. They just help the sporran strap from falling off really skinny hips.
You may also find that the pattern of the pleating may be off center too if your kilt is pleated to the Sett. You can't correct this and will just have to live with it.
But hey, your kilt will fit, you get bragging rights that you did it yourself, and two or three hours sitting sewing your kilt is a lot more fun and relaxing than the same time sitting and watching TV.
ps. If you stick yourself while sewing it's considered good luck.
22nd February 08, 01:49 AM
Ted,
in case you haven't seen it yet over on your other (gardening) thread, I mentioned you might also consider the "Bison" colored Lewis hose along with the brown ones. The Bison is a tan-oatmeal color (some might call it a grayish-brown).
I think black garters would compliment both these & the brown hose, and go well with your weathered Lamont.
22nd February 08, 11:11 AM
 Originally Posted by BoldHighlander
Ted,
Thanks BoldHighlander. MacMillan of Rathdown had suggested the snuff colored hose, so until he says otherwise, I will assume that he was talking about the Bison colored hose. I was planning on looking for snuff colored hose on the web sites, so didn't ask him what color that is when he was posting in this thread; my goof up. Also thank you for the suggestions on the garter ties. It is easier to get away with a little dab of black on the brown than a dab of brown on black, and the Lamont does have the black lines in it. I'm mostly thinking of the fashon rule of not mixing black and brown like wearing a brown shirt with black pants, or using black shoes with brown belt and so on.
22nd February 08, 05:15 PM
This is a link to where the idea for my corduroy jacket conversion began. It's a thread called "Black Cororoy jacket conversion" by James MacMillan.
http://www.xmarksthescot.com/forum/b...ket+conversion
23rd February 08, 08:11 PM
I found a couple more threads about sports jacket conversions.
Farlander's thread, "Converting a tweed sport coat to a Crail jacket"
http://www.xmarksthescot.com/forum/c....html?p=496170
David Dalglish's thread on the curved front at this link.
http://www.xmarksthescot.com/forum/j...x.html?t=22201
Both of which are helpful. It turns out that I will have to find a different person to help me with my jacket conversion. I have the jacket and have been trying it on with the kilt and sporran. I think I have a good idea of where the bottomm of the jacket should be and where the cut away for the sporran should be. The vest seems like it might be a little bit too tight, so I might hold off on that part untill I find more information on what a vest is supposed to be like for a kilt. It's too tight to fit over the top of the kilt. It would need to be shorter in the front to not stick out from under the converted jacket anyway. I'll try to find a better way to ask the vest question, then post it.
Here are some good threads by Alan H
http://www.xmarksthescot.com/forum/s...x.html?t=21573
http://www.xmarksthescot.com/forum/m...x.html?t=14252
Have Iron, will travel to Stillwater
http://www.xmarksthescot.com/forum/h...x.html?t=14556
For wool tape:
100%-Worsted Wool Twill Tape from Wooded Hamlet Designs
24th February 08, 11:18 AM
As an update, I will probably be having someone new looking at the corduroy jacket to see if a conversion would be possible. I will also be looking for a matching leather belt to use with the sporran.
If I am able, I will get pictures of the jacket being worn with this kilt before the conversion and after. I haven't given up on this idea yet, but at this point I am thinking about just looking for a kilt jacket. I haven't seen any done in corduroy yet, though. As far as the matching vest, I still don't quite know how the vest is supposed to be worn with the kilt, and the vest I have is a tiny bit too tight. It doesn't fit over the top edge of the kilt too well. If the vest were worn under the kilt, it seems to fit a little better. I figure that is not correct though.
* After trying on a few other vests that go with other suits, I am completely sure that the matching corduroy vest for the jacket is too small for me. I don't know if it can be made larger, but I will ask. Also, the back of this vest is made of satin materiel, so can't be worn on it's own.
I'm trying very hard to not start another thread on this yet, so I may post these questions in other places. When I have pictures of the jacket to post, I will think about starting a fresh thread.
* Moving the folowing to this post to make room.*
Here's a long boring post to keep the thread alive. I had the brown, corduroy jacket and vest looked at by a lady who has done a little sewing and she says the jacket should be easy to shorten and the vest can be widened, but not by her. It gives me hope, so I will find someone to do the work.
There is a little bit of history behind this jacket and vest. It belonged to my step father. He had it made for himself when he was a teenager while living in South Korea; his father was a Colonel in the Air Force and stationed there in the seventies. My mother was going through a bunch of my step father's suits that no longer fit him and gave me several of them; I think I have five or six of them...
The corduroy jacket shows no wear, and looks to be well made, so I am choosing to stick with this conversion project rather than try to find a pre made corduroy, kilt jacket. I like the texture of the corduroy in combination with the wool of the kilt, and it is a cooler materiel for out here in the desert. It also has a bit of an unusual history behind it, and this is the reasoning behind putting it back into use.
* Also, could anyone explain to me if the botum front of the vest should extend passed and show in the sporran cut away on a kilt jacket?
* I saw a thread where Hamish posted that the kilt jacket should really never be buttoned when wearing a waistcoat. There was also some talk of not buttoning the jacket in general, but I'm not too sure about that. I still don't know if the vest can be left as is in the front.
Links to Hose and Flashes
Kilt hose observations
"Formal Hose--loads of questions -"
Mael Coluim's Cream/White Hose or NOT
thread on washing kilt hose
"Traditional Garter Ties"(how to tie them)
Barb T.'s thread "Making your own extra-swell tartan flashes"
The Scottish Tartans Museum's "LEWIS KILT HOSE"
24th February 08, 06:18 PM
25th February 08, 10:38 PM
Jacket Conversions and Patterns
By auld argonian in forum How to Accessorize your Kilt
Last Post: 10th March 07, 07:19 PM
By Jewddha in forum Kilts in the Media
Last Post: 27th April 06, 12:13 PM
Last Post: 19th September 05, 08:33 PM
By richardljohnson in forum Kilts in the Media
Last Post: 13th August 04, 03:42 AM
