Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
    18th June 07
    Canada
    Rolling this over in my mind, I wonder if an inner belt like what is used on a gunbelt would be of any help? The sort of thing I'm thinking of is used to secure a heavy belt with pistol, magazines, etc., so it should certainly hold up anything short of a lead-lined kilt. It has an inner belt with the outer surface made of Velcro (tm), and a ring of the opposing Velco surface stitched to the inner waist of the heavy belt (or, in this case, kilt), and putting them on and taking them off is a simple matter of pressing them into place. Just an idea, if someone wants to run with it.
    20th August 09
    New Brunswick, Canada
    There was a similar idea put out there, basically a high friction material belt you wear inside that would cling to both longer and my waist. I am hoping that part won't be an issue, i think I have the curves to hold up the kilt and I took my torso measurements with that in mind.
    I can only hope....otherwise, yes, I am sure there is a solution.
  1. nervous in my kilt
    By mfl243 in forum Kilt Advice
    Last Post: 9th November 08, 09:36 AM
  2. Replies: 28
    Last Post: 3rd May 07, 09:40 AM
  3. Nervous
    By Derek in forum Kilt Advice
    Last Post: 8th June 06, 08:51 PM
  4. I am bloody nervous right now.
    By Rob Wright in forum Miscellaneous Forum
    Last Post: 12th April 06, 07:17 AM
