Page 1 of 5 123 ... LastLast
Results 1 to 10 of 56
    28th April 06
    Sanford, NC
    Airplane on a conveyor belt
    Ok, this question has been floating around the internet for a while and since we have a couple of pilots here as well as some very educated gents, I'll pose it here. If an airplane is placed on a conveyor belt that is moving in the opposite direction of the airplane's thrust, but at the exact same speed as that thrust would generate - i.e. holding the aircraft in place on the belt, would the plane take off once its speed reached the appropriate level? I say no because simply put, thrust serves to move the airplane forward through the air which provides lift. if the plane isn't moving through the air, there is no lift. What say yee?
    I'm a well rounded guy - English motorcycles, Irish brew, and Scottish clothes and music.
    1st November 07
    Northumberland, UK
    Theoreticly, no, it would not take off.
    However, this theory seems a little flawed. The undercarrage of the aircraft would not provide enough resistence to stop the aircraft moving forward, even though the conveyor was moving backwards, after all, in an aircraft, the engines push against the air, not turn the wheels.
    So, where you to calculate the accelleration of an aircraft on a normal runway, and program a conveyor belt to replecate the acceleration in the opposite direction, the aircraft would still move forward. It would not accellerate as quickly, but it would still move forward. The main danger would be that the wheels may pass their rated speed limit and suffer a failure
    Ofcourse, I'm also assuming that the breaks would not be applied, which would change the situation again.
    I think this question must have been asked by someone with little knolage of aircraft, and unconciously expects the wheels to be providing the forward force, as with a car.
    Aircraft fly due to aerodynamic lift, the word itself gives you the clue, aero dynamic = moving air.
    There are exceptions that break the rule, for instance, the Harrier and the LightningII whcih vector the engine thrust to counter weight rather then drag, and then accelerate once airborn to begine to generate aerodynamic lift.
    31st December 05
    Bernouli's Principle. No lift, No fly.
    16th December 05
    Maryland USA
    The airplane's thrust pushes against the
    air, not the conveyor. The airplane would
    begin moving through the air, regardless
    of the motion of the surface below the
    wheels. When the plane is moving through
    the air fast enough, it may take off if
    given the appropriate control input by
    the pilot.
    The thrust pushes the aeroplane though the air so it would accelerate just as fast on the conveyor belt as it would on a runway. Only difference is the wheels would turn faster. I think the added friction from the belt trying to move the wheels the other way would be marginal, so if there was any difference in the aroplane's acceleration it would only be very slightly slower.
    24th December 04
    Why do people always think airplanes gain speed on the ground through their wheels?
    The motive power comes through the air, not the wheels. Whatever happens to the wheels is irrelevant. The plane would take off and never notice the conveyor beneath it, though the wheels would spin faster.
    Think of it this way, on take off, when the wheels first leave the ground does the plane suddenly come crashing down because it lost it's motive power? Of course not, it continues to accelerate and gain altitude.
    Now, in the real world the moving conveyor would provide some rolling resistance which would need to be overcome, but at most it would require a bit more thrust to simply achieve take off speed, and not even much more at that.
    For those interested, I believe the Mythbusters are testing this myth soon. Actually they already tested it, and are airing the episode soon.
    29th September 07
    Michigan
    Quote Originally Posted by Yaish View Post
    Dec 12
    MythBusters Air Plane Hour
    Jamie and Adam take wing to test if a person with no flight training can safely land a 747 and if a plane can take off from a conveyor belt speeding in the opposite direction. Tory, Grant, and Kari jump on some Hollywood-inspired skydiving myths.
    29th September 07
    Michigan
    Don't the wheels allow forward progression to create airflow to create lift? Granted you can take the wheels off and put on a skid plate and the plane would still be able to take off (think float plane). However the plane is moving in a forward progression.
    Through the air is key here I think. Without forward progression you have no through the air. The air remains constant. I don't believe there is any airflow when you walk on a treadmill.
    Because the plane has/is gaining lift.
    Here would be the thing. The conveyor belt would have to increase speed as the thrust increased other wise it would be just like a runway. If not, the thrust would win and you'd have forward progression creating airflow to cause lift.
    24th December 04
    Quote Originally Posted by JohnsonK View Post
    You will have forward progression though. Why do you think it won't? Remember, the wheel do not provide any motive power, so what does it matter if they are moving? The motive power comes from either the thrust of the jet exhaust or the thrust of the spinning props.
    Can a boat travel upstream? Same exact principle.
    Imagine you are standing in front of a treadmill. Now on the treadmill is a toy car, and you are holding a string attached to the car.
    If you pull the string does the car move forward on the treadmill? Of course it does, because the motive power is coming from somewhere other than the wheels in contact with the treadmill. Same exact thing for an airplane.
    You cannot use the walking on a treadmill analogy, since your motive power would come from contact with the ground. An airplanes does not.
    The plane would be gaining lift regardless of what the treadmill was doing. The treadmill could be moving at 100 times the forward speed of the plane, it would just make the wheels spin faster. It would have no effect (other than a small effect due to friction) on the progress of the plane.
    Say it along with me folks "PLANES DO NOT DRIVE LIKE CARS".
    28th April 06
    Sanford, NC
    See that's my point. To me, the question indicates that the speed of the aircraft is it's ground speed, otherwise it wouldn't be on the treadmill. So, if the ground speed of the plane matches the speed of the treadmill, the net forward speed to an observer on the ground is zero, thus no moving air and no lift.
  1. New canvas red sporran, and old belt buckle from a belt
    By Scotexan21 in forum Show us your pics
    Last Post: 23rd January 07, 03:57 PM
  2. Belt or No?
    By ckelly327 in forum Kilt Advice
    Last Post: 4th July 06, 03:40 AM
  3. Kilt Pin and Airplane Security
    By krooks in forum Kilt Advice
    Last Post: 20th June 06, 05:21 AM
  4. Sporran belt inside or outside kilt belt?
    By JockEleven in forum Kilt Advice
    Last Post: 14th September 04, 01:37 AM
  5. chain mail belt as utilikilt belt any opinions
    By kilted in KC in forum How to Accessorize your Kilt
    Last Post: 17th June 04, 09:32 PM
