Results 1 to 9 of 9
    17th June 05
    Jacksonville, FL
    Question Appropriate Fitting Q's
    Quote Originally Posted by kiltedpride
    A badly made kilt on the a guy or a fashion kilt as opposed to a traditional kilt can of course detract immersurably.
    First, look at the image in the post "Dressed to kilt" on the "Kilts in the Media" thread. [I couldn't insert the pic here.]
    My questions are: 1. Is that normally the height (i.e., just above the navel) to keep in mind when measuring yourself for a kilt? 2. The kilt pictured is traditional, but is there a particular style shown in the picture? 3. [Completely unrelated] How will the traditional lightweight wool tartans feel/hold-up in extrememly hot weather (I live in Homestead/Miami)?
    macwilkin is offline
    Retired Forum Moderator
    Forum Historian
    22nd June 04
    wool & the heat...
    Remember that Scottish soldiers in the British Army did wear kilts in other "tropical" climes such as the Caribbean, India and South Africa, as well as wool tunics.
    I have read of folks in Florida and other "hot" places wearing traditional kilts with jackets made from lightweight cotton/linen, etc.
    Todd
    24th April 04
    North Dakota
    Good-morning!
    Just a thought (remember I'm no expert here) perhaps the choice of a 4 yard casual kilt rather than a eight yard "tank" for the climate there might be better.
    Bill
    May all your blessings be the ones you want and your friends many and true.
    8th June 05
    Lafayette, LA USA
    Quote Originally Posted by cajunscot
    Todd
    And, you can get your tartan made of cotton as well. Depending on the tartan you choose (not all clans tartans are offered) it can also be a lot less expensive than wool and will wear a bit cooler as well; that is, if you're not a "strict" traditionalist.
    Dreadbelly is offline Membership Revoked for repeated rule violations.
    15th August 04
    PV!!!
    It breathes better than wool. Also wicks away moisture and has a good evaporation rate.
    Good stuff that for hotter climes.
    2nd April 05
    Key West, Florida
    Normally the waist measurement is taken around the naval, but follow the measuring instructions from the kilt maker.
    I have a 13oz 8yd I wear here in Key West and have not been uncomfortable in the heat down here. I will be getting a 5yd hillwalker, not because of the weight but because of the price.
    I got mine from Alexis Malcolm. She use to be based there in Homestead but recently moved up to Clewiston.
    17th June 05
    Jacksonville, FL
    Perfect!
    A kilt maker in Clewiston --close enough to drive to in 2-and-a-half hours. Thanks for the tip, Gator, and pop me a private message. (I go to Key West often for work, maybe we can grab a bite to eat...)
