12th August 05, 09:18 AM
Hey Barb...
I have a couple 16-ounce kilts here that are in need of serious repair. Both were made the "proper" way (for the most part) but aren't working for the owners. Both are having serious issues with the left side of the front apron. Both are curling-out with serious pulling on the apron itself.
The question is one of simplicity.
Rather than have to disassemble the beltline/cap, and have it altered to "bring-in" the under-pleat by pulling it up just a notch... is there a way to use a hidden stitch or stretch the fabric with ironing to get it to lay properly? One of the guys tried to iron a wider taper in the edge, and it helped a bit. Once he loosened the hip-buckle on the right hip, it helped too. But, there's still a pronounced pull.
These kilts are pretty old, and I'm a little hesitant to disassemble them due to the age. The fabric is solid, and the weave is dense. The stitching is also VERY tight, so ripping the seams is a scarey proposition.
It almost appears like it's going to be a combination or "repairs" to get them to hang like they should. What do you recommend to be the most evasive and still "git-r-done"?
Again, these kilts are wool traditionals... not machine sewn or casuals.
Thanks in advance... AGAIN.
Arise. Kill. Eat.
