"Using this number as an example: +44 (0)870 555 5555"
When calling the UK from the USA you would dial 011 44 870 555 5555.
The 011 tells the phone switch that you are dialing international - you dial this for every international call you make in the USA
The 44 is the country code for the UK - each country has their own code
You drop the (0) when dialing internationally from the USA
The remaining numbers are the actual telephone number you are dialing.
Hope this helps! Remember, most cell phones will not allow international calls unless you specifically have an international plan, also most 'office' phones, those you have to dial a '9' to get an outside line, are not able to make international calls either unless programmed to do so at the switch.
Brian Mackay
"I find that a great part of the information I have was acquired by looking up something and finding something else on the way."
- Franklin P. Adams
