Results 1 to 4 of 4
    27th January 05
    Jefferson, Georgia, USA
    Leather Kilt Strap Pattern
    Can someone who has a set of leather kilt straps take a few measurements for me.
    I'm wondering what the typical overall length is of both sides (the side with and the side without buckle).
    Whoever I get my next kilt from I want to make my own straps and use these satin silver finish buckles I've got. They are for a 1.75" strap so a bit wider than normal but the buckles are thick beefy buckles which I think will kook great.
    Typical hole spacing would be helpfull as well and how much leather is needed to stitch it to a kilt.
    Thanks
    An t-Ileach's Avatar
    An t-Ileach is offline Oops, it seems this member needs to update their email address
    28th June 05
    Preas a'Chiobair/Shepherd's Bush, Lunnainn/London RA/UK
    Length is 6" overall (1" stitched in - you can get away with 3/4") for a strap 1 1/4" (both sides)(but I think you could vary them so that the apron sits in the right place for you). For a strap 1 3/4", I'd add 1/2". Holes (5) are usually 'strap width less 1/4"' (centre of hole to centre of hole), but an interval of 1 1/2" seems rather a lot - what about 1"?
    22nd April 06
    Great looking buckles. Good luck with the project. I think the above post sounds about right. I'll try and get the measuring tape out tonight when I get home.
    4th March 06
    Tartan Hiker makes a good set o' straps. He can give you some tips.
