Results 1 to 7 of 7
    4th March 06
    How to care for your kilt without washing
    I've found a fantastic ( an cheap ) method to keep your kilt clean without water! It is a simple rubber dog-hair removal brush.
    here is a link to one at walmart:
    http://www.walmart.com/catalog/produ...uct_id=3635649
    lay your kilt out flat, set the pleats correctly, and brush the kilt from top down, in short, quick strokes. The rubberized bristles remove hair and most large particles of dust, dirt and other such things. It works very well, and only costs a few dollars. So far I have not seen any damage from using this on my kilts.
    Hope this helps!
    27th March 06
    Ferintosh, Dumfries, Scotland
    an ya cuid wear a flea collar roon yur waist tae keep them wee beasties awa'!
    HA!
    31st May 06
    Quote Originally Posted by Pour1Malt
    HA!
    Wonder if it would work on Mosquitos/Skeeters, gnats, and Midgies (gnats from HELL)?
    16th December 05
    Maryland USA
    Does it get out the stinky oily perspiration?
    4th March 06
    Quote Originally Posted by Robinhood
    hmm...I'm not sure of that...somehow I doubt it...
    best bet is to have Matt Newsome make you a new kilt, especially if your old one smells that bad!
    starbkjrus's Avatar
    starbkjrus is offline
    Member - X Marks Honor Roll
    29th July 05
    Hmmmm. So now not only do I have to groom my cat I have to groom my kilts?
    hehehehehehehehehe
    Dee
    Ferret ad astra virtus
    7th April 05
    Montréal
    Brush and steam
    Prior to dry cleaning, the traditionnal way of cleaning wool suits was called brush and steam. First, you brush the suit (or the kilt) with a suit brush, to remove most ot the dirt. Second, you expose it to steam (hanged in a closed bathroom with hot water in the tub) to remove bad odours and to eliminate creases.
