25th June 06, 08:30 AM
Please clarify reverse pleats
I'm planning a kilt of denim, and want to understand reverse pleats for this sort of casual kilt. I will be doing pleats of 2 inches reveal and 2 inches deep. At the left apron edge there will be a pleat with a depth of 2 inches, so should the reverse pleat on the right be the same depth? Or would it be better to make one or both of these deeper for functional purposes?
25th June 06, 08:39 AM
Hi Eric
Someone with casual kilt experience should chime in on this, but, in a trad kilt, there is a deep pleat beneath the edge of the apron (it's not really the first pleat, just the fold-back of the left apron edge) that is typically deeper than the other pleats. I try to make mine a minimum of 4.5-5" deep (i.e., uses up about 9-10" of fabric). Gives more freedom of movement to the apron.
On the other side, there's an inverted pleat (the last pleat is normal, but the underapron edge folds under to the left, toward the underapron center, forming a big box pleat, basically). I try to put a good 3-4" in each, partly for movement and partly to give some fabric in case the kilt has to be let out.
For a casual kilt, I don't know what the typical procedure is.
Barb
25th June 06, 01:02 PM
The pleats under the apron are important as they define how far and how easily the aprons will fall vertically when you sit - but also how easily and how far they will fly up.
Now with denim I would not think you would have much trouble with the fabric flying in the breeze, so it might be a good idea to make fairly deep under apron pleats and to have small pleats for a few inches more than half the hip measurement, so that the apron and under apron slide easily and drops between your knees for confident sitting.
For me 2 inch pleats is a bit skimpy - but I tend to be generous in most things. Just be sure that when you sit down there is going to be enough material to go round.
I make my kilts in a reverse Kinguisse style, so the two sides are mirror images, with the small pleats pointing to the back where they meet in a large inverted box pleat. The two aprons are hemmed straight at the edge of the fabric, but shaped within the length, so I make a pleat 2 inches deep which is pressed out so the bottom edge of the aprons are 2 inches wider than at the waist edge, and then I make a large under apron pleat and only then start the small pleats.
This style suits me better than the traditional or the original Kinguisse style with the pleats opening towards the front - I catch then on everything around the garden and even in the house.
25th June 06, 08:12 PM
I know the pleats I plan for this are a bit shallow at 2 inches but I haven't worked with denim so I'm concerned about my sewing maching getting through a lot of layers. I'll have 9 pleats using up 6 inches each so that adds up to 54 inches not including the reverse pleats, which may add another 15 to 20 inches per your suggestions for reverse pleats. With apron that could add up to over 90 inches all around. I'm not sure I can spread my legs far enough to need more fabric than that, but I'll give it a try (ouch). I'd like to have deeper pleats, but until I experiment with denim more I'll take it slowly. Thanks for your suggestions. More are always welcome....
26th June 06, 12:00 AM
It is my personal opinion that denim makes a terrible fabric for kilts. It is a very stiff and unforgiving material. It's ok for jeans because you are inside them, always stretching the fabric out to shape. In a kilt the fabric WILL shrink and pucker. Look at the seams of your jeans, see those puckers? That is what each and every pleat edge you stitch down will soon look like. Unless of course you just love ironing.
Not everyone agrees.
But if you have decided on denim then my comment would be to include as much fabric as you can possibly afford. My work weight kilts have between 7 and 9 inches of "Sett". (depending on model) With a reveal of either 1.5 or 1 inch that makes the pleat depth between 3.5 and 4 inches.
On the left side of the outer apron is the deep pleat. This pleat needs the depth to allow the aprons to hang correctly when standing and to allow room for you to sit and have the apron fall between your legs. On my kilts this pleat is half the depth of the width of the apron.
On the right side of the under apron is the reverse pleat. This is just like the deep pleat but because it also reverses the direction of the pleat it gets a special name. (Think inverted or reverse box pleat). On my kilts this pleat depth is also 1/2 the apron width.
I hope this helps. I'm not trying to discourage you from your endevour but trying to help you from making something which after two washings starts to look like a tutu.
26th June 06, 09:11 AM
Thanks, Steve. Those are mighty deep side pleats. If my apron is 18 inches wide that would make them about 8 or 9 inches deep. Is that what you meant to say? Hmm. That's like three aprons worth of fabric in front, not counting the inner apron. I'm not trying to cut back on fabric, but I think I'll go more moderate. It seems that for apron-dropping purposes, 4 or five inches deep would be sufficient. That would give 16 to 20 inches of fabric to unfold as knees spread, giving a minimum of 34 to 38 inches to hang knee to knee on me, which is a lot.
I'm thinking perhaps you meant that all the hidden fabric in the deeper side pleats equals half the apron width, meaning for an 18 inch apron they would use 9 inches of fabric and be 4.5 inches deep. Is that right?
Regarding denim seams shrinking, one thing is for sure, they use cotton thread on jeans, which itself will shrink differently from the fabric. Good to point out that hazzard, though. So have you tried doing denim with maybe an all polyester thread, or a blend? Another trick would be to use a zigzag stitch, but that would probably look funny. I have in the past put hems on jeans that never puckered with many washings, so that must have been poly or cotton/poly blend thread.
I also noticed on the jeans that I have that the stitch they use is somehow not just an ordinary straight stitch, so that may figure in as well.
We shall see, we shall see.
I've also been warned by a seamstress to beware of selvage that may have different fibers or weave, and therefore shrink differently than the fabric itself.
