Results 1 to 10 of 15
    23rd January 04
    from England now in Ontario Canada
    I need advice on great kilt
    thinking of doing a great kilt.
    does anyone have instructions?
    would be better if instructions had photos.
    thanks
    Southern Breeze's Avatar
    28th August 05
    Chatsworth Georgia, USA
    I asked the same thing several months ago. I was refered to the following site. It was extremly helpful and answerd the question quite well.
    http://www.kalani.net/KiltPleatingB.html
    23rd January 04
    Quote Originally Posted by Southern Breeze
    thanx man, I'll check it out
    14th March 06
    Here is another site with photos:
    http://www.gaykilts.co.uk/feileadh%20mor2.html
    Happy folding
    23rd January 04
    Quote Originally Posted by gilmore
    Happy folding
    thank you
    16th August 06
    Sacred Tomato, California, USA
    I've found each of thse sites helpful in my quest to figure out how to don a Great Kilt.
    http://www.lindaclifford.com/GreatKiltWrap.html
    http://www.kalani.net/KiltPleating101.htm
    http://www.brotherguido.com/Greatkilt/Default.htm
    http://www.garbtheworld.com/pgs/foldkilt.html
    Of course, as my brother-in-law used to say, "practice makes better."
    --SSgt Baloo
    5th September 05
    Chicago
    30th November 05
    Mountains of Utah U.S.A.
    What is with :
    Lookes like he is doing the pleats the long way???
    MrBill
    Listen to kpcw.org
    Every other Saturday 1-4 PM
    23rd January 04
    Quote Originally Posted by auld argonian
    great video thanx, but what happened to the rest of it
    31st May 06
    Quote Originally Posted by mbhandy
    What is with :
    MrBill
    He is a VERY small guy. I've seen that before.
    His method would NOT work on 6'1" 200 pound me.
    The drawsting method is historically probable:
    http://albanach.org/drawstring.htm
    Otherwise, many of the methods are pretty much the:
    1. lay material on ground
    2. put belt wear waist is (slide under fabric)-align to bottom at knee or above
    3: hand gather so:
    -right apron=1/2 body diameter
    -gathered area=1/2 body diameter
    -left apron=1/2 body diameter
    4. lay down so backside over gathers and belt at waist
    5. pull right hand (as laying down) over to left
    6. pull left hand apron over right (so top edge is on right hip)
    buckle belt
    (up to here-> draw string would be easier- slide belt/rope through loops and gather-> make front aprons as above-> put a wide belt over aprons and around waist)
    Play with various to arangements to see what like.
    A few good ones:
    http://www.xmarksthescot.com/forum/s...t=belted+plaid
    Also-> tie upper corners together and put behind neck,
    pull back up, so makes rain cover
